Gutting the cat from OBD2 car?
Old Sep 13, 2002 | 12:48 PM
Hard2Find's Avatar
Default Gutting the cat from OBD2 car?
im planning on gutting my GSR cat (obd2) since my planning on dropping my exhaust and run straight downpipe (FMAX turbo)
will i get a CEL?
Old Sep 13, 2002 | 12:52 PM
Reid's Avatar
Global Moderator
Default Re: Gutting the cat from OBD2 car? (Hard2Find)
Yes, code 67.
This will not affect performance at all.
Old Sep 13, 2002 | 12:55 PM
Hard2Find's Avatar
Default Re: Gutting the cat from OBD2 car? (Reid)
and code 67 will be Secondary O2?
even though i put both O2 sensor back?
so it shouldnt affect my performance? how so? i thought when you have CEL...the ECU will be in default mode and will dump alot more fuel?
Old Sep 15, 2002 | 08:30 PM
PoW3l2BaN's Avatar
please do not gut your stock cat...those obd2 cats are worth a few hundred bucks...around 600 for a new one..there are no obd2 replacements yet so save the cat and go carsoud or stright pipe....you can make a lot of cash selling your stock cat to some muffle shop or so..
Old Sep 15, 2002 | 08:47 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Gutting the cat from OBD2 car? (PoW3l2BaN)
Get a test pipe. As mentioned above, stock cats are stupidly expensive. Actually, you *should* just get a larger-diameter high flow cat instead. 2.5" downpipe, 2.5" cat, 2.5" b-pipe and you will be happy.
Old Sep 15, 2002 | 08:52 PM
OutLaw MR's Avatar
don't do it!
Old Sep 15, 2002 | 09:01 PM
speedymon's Avatar
Default Re: Gutting the cat from OBD2 car? (OutLaw R)
strange..... I'm running straight pipe w/ my turbo setup and i'm not throwing codes. 96 GSR here w/2.5" dp and 3" back. Both o2s hooked up and everything.
Old Sep 15, 2002 | 09:16 PM
B2FiNiTY's Avatar
Default Re: Gutting the cat from OBD2 car? (speedymon)
Maybe you or the previous owner took out the CEL bulb.
Old Sep 15, 2002 | 09:25 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: Gutting the cat from OBD2 car? (ExOdy)
I run around open header/test pipe and it can take me 1,000mi before I'll finally throw a code.
Old Sep 15, 2002 | 09:56 PM
Nameless RB26's Avatar
Default Re: Gutting the cat from OBD2 car? (ActiveAero Ninja Edition)
Why would cats be so expensive? They are ****... and it's stupid that you can't buy a used one legally. (Yah I tried)
Don't gut the cat though.
Old Sep 16, 2002 | 07:42 AM
speedymon's Avatar
Why does it take that long to throw a code? Does the O2 finally burn out or something? No the CEL is not removed. I was throwing codes before.
EJeff8
18
Aug 20, 2010 11:47 AM
no2unenolife
Oct 31, 2005 03:08 PM
Electron Si
15
Feb 11, 2004 02:57 PM
Sivik
Jul 26, 2003 07:06 AM
m0t0rhead
May 7, 2002 05:16 AM
