FS/FT> 00 Si B16 Quaife trans, 81mm Arias piston, Gsr/B16 Cams, Eagle rods and more
81mm 9:1 Arias piston with rings BRAND NEW 350, mounted on LS rod but never used
Set of GSR and B16 Cams, 80 for gsr 50 for b16
Set of B18a/b/ B20 Eagle rods, three are good one bad due to spun rod bearing.
B-series Manual starter 60
Shaved B18/B20 Valve cover 40
94-01 3DR Integra Cargo cover 30
http://s11.photobucket.com/albums/a1...5.jpg&newest=1
2000 SI S4C Transmission with Quaife LSD, no pop or grind came out of my boosted set-up. Im switch to a GSR trans due to running out of gear on the b16, will trade for GSR+cash or a Quaife/M-factory GSR trans.
WTB, Parts i need or will trade for or buy outright
GSR Transmission, could be in good shape/grind/pop out of gear/ crack case.
ITR/CTR Cams
Im located at the Mass/CT border
ITR/CTR Cams
StolenTeg
Aug 17, 2010 07:52 AM
KeyserSoze
Feb 12, 2007 01:38 AM
