My tune is running super rich at idle...any easy fixes?
Old Jun 10, 2010 | 02:07 PM
erikiksaz1's Avatar
Default My tune is running super rich at idle...any easy fixes?
I just recently popped in my old P73 ecu to go on a long-distance drive when I noticed that the smell of exhaust fumes is greatly decreased compared to my tuned P28.
My car was tuned a couple years ago, and it wasn't until I threw on the stock ecu that I noticed that my car exhausted that much more heavily with the P28. Without bringing my car back to the tuner, is there much I can do? Can local tuners just lean it out a bit, or is that unsafe without a full tuning session?
Old Jun 10, 2010 | 02:52 PM
havok hybrid's Avatar
Default Re: My tune is running super rich at idle...any easy fixes?
Drop your fuel pressure a few say from like 60 to 45. or it your at 45 got to 40 . .. . With the Tuned rich ECU is installed..
Hit a local spot that can burn a map with crome. Have them take a look .
Or Go in for the full retune.
Old Jun 10, 2010 | 10:09 PM
mouab18c1's Avatar
Whichever ecu your car was tuned on is the ecu you should run. Changing it to a p73 ecu is changing all the fuel settings.
Old Jun 10, 2010 | 10:51 PM
DDTECH's Avatar
Whats your car tuned on.. i can edit it, if you want.
Old Jun 11, 2010 | 02:39 PM
erikiksaz1's Avatar
The motor was a jdm itr, so I was just running the stock ecu (p73, unless I have the numbers wrong It's been a while since I've read up on this stuff)
It was tuned on crome.
Gas mileage should typically be better on tuned ecu's, no? Seems like I usually get worse mileage with this tuned ecu than stock.
Corksil
23
Jul 14, 2011 05:59 PM
turbogsr181
Jul 21, 2006 10:22 PM
tuan...
Jul 17, 2005 07:03 PM
