b series parts for sale
It’s time to clean out my garage in order to make room for parts that I have just gotten for my upcoming months long build.
In my garage I have:
3 LS valve covers (one black 2 white)
1 set of OEM DA Springs and struts (put on my car and took off two days later because my backs are bad)
1 oil pan set up dented from ride height
1 1992 oil pump used (took off my b18a1 for 96 plus)
1 IAC (came of DA9 that I spun a bearing; worked before removed)
2 motor mounts (not sure on which haven’t looked to compare with my car)
2 LS heads (no cams, ones 98 on a block with spun bearing, other is 92)
2 LS intake manifolds (92, 98)
2 sets of LS cams (92, 98)
1 set of b16 cams (got in a sale with my gsr vtec head)
1 p75 obd2 ecu (manual- case rusty but ecu is good) has 0bd1-0bd2 jumper needs a minor repair free if ecu is bought
1 LS bare block (98 spun bearing, has water pump and brackets to hold crank in will include the ls rods it had and the crank that will need to be repaired)
1 AEM sticker
1 LS spark plug wire set (worked when they came off my car)
1 disty cap (tall version)
1 disty cap (short version)
2 sets LS injectors (worked when removed)
2 stock LS fuel rails (missing ends caps I believe)
1 B-series started (started my da9 hasn’t been used in a few months)
1 Speed sensor (cable transmission)
2 OEM LS cam gear sets (pr3)
1 stock OEM car jack (personally haven’t used has handle to jack and lower)
1 power steering pump (pr3-3 was on my db1 with no belt so I removed)
1 OEM gsr intake manifold (no butterflies but plate still there)
I also have some elbows and flanges that came with a turbo kit I had if anyone may need a part. Also a Apexi v-afc (vtec airflow converter) never installed on my car. Was told it was of working condition. All items are best offer since I need to make some money to get after market LS rods and such to build a block. Please PM me with questions and pictures since there are many items or text me at 2034909268 and ill send a picture.
1 AEM sticker
