getting ready to change timing belt and water pump
Old Jun 10, 2010 | 09:31 AM
Michael.K.Conte's Avatar
Default getting ready to change timing belt and water pump
so, im building my 1993 del sol si one peice of time cause i aint got no dime (jonny cash reference) and i have a leak in the water pump.
soooooo since that needs replaced, im going to replace time belt while im at it, 171xxxmi and stock belt lol according to the last and only owner before me.....
i want this car to be steet machine, low end torque, etc...... no plans for regular track racing.
i have $180 to buy the parts i need online. what else should i do while im down there? cam gears?
Old Jun 10, 2010 | 11:44 AM
Cynical 1's Avatar
Default Re: getting ready to change timing belt and water pump
just use the cash to get a quality waterpump and timing belt kit.
cam gear doesn't need replaced - unless you want a pretty one on there...
Old Jun 10, 2010 | 11:54 AM
would it make sense to upgrad to a better gear? i heard that in the si the stock one is adjustable....
Old Jun 10, 2010 | 01:25 PM
Vindicator9000's Avatar
318 Curves, 11 miles
A stock DelSol Si just has a regular d16z6 I believe, which isn't adjustable.
An adjustable cam gear provides no benefit to an otherwise stock engine. Just do timing belt and waterpump, and don't forget to get the waterpump gasket.
On a D series, the only engine mods that make a serious difference are:
z6/y8 transmission
z6/y8 head
z6/y8 intake manifold and airbox
y8 exhaust manifold
turbo (and everything that goes with it)
Seriously, the D-swap stuff can make a big difference on an otherwise stock car. If you've ever drove a CX EG before and after a d16y8 swap, you'll know exactly what I'm talking about... completely different car.
There is very little you can do to a stock D-series to make it ANY faster naturally aspirated without dropping a TON of money. Your best bet is usually to build it into a z6/y8, then turbo. Now, if you really are serious about doing things to it while you've got it apart, changing the timing belt is a good time to swap the head. It's a lot of the same work. I've seen decent heads go for around $100 used.
Old Jun 10, 2010 | 01:52 PM
95civtecex's Avatar
I would also do the cam an crank seals while your there, there like 8 bucks or so an my water pump came with the gasket actally a rubber o ring thing so look an see if you one your gettng has it could save you some money
Old Jun 10, 2010 | 02:24 PM
thanks guys, im gonna get one of those pump/belt kits online for like 150... has all o rings and gaskets hoses etc, if its anything like the rest of the car was when i got it ill need them lol
fujiwaratofu86
Feb 16, 2013 12:07 PM
5.56
Jun 17, 2009 05:19 PM
realis9
Aug 26, 2007 12:05 AM
SuperSteve737
Apr 4, 2006 03:33 PM
