Suspension & Brakes Theory, alignment, spring rates....
Does bleeder valve need to be opened?
Old Jun 10, 2010 | 08:39 AM
leonardotmnt's Avatar
Default Does bleeder valve need to be opened when changing brakes/rotors on a 2000 Integra?
When changing the front brakes on a 2000 Integra LS do I have to crack the bleeder valve before compressing the piston? I've read that you have to on ABS systems so you don't force the fluid back through and damage the ABS but it doesn't mention it in my repair manual. I just want to see which way is correct before doing it wrong. Thanks!
blkdoutteg
Suspension & Brakes
May 12, 2014 06:02 AM
ZCHondaCRX91
Suspension & Brakes
Feb 4, 2012 09:18 PM
nikolai.
Jan 12, 2007 11:08 PM
_gurusan_
Mar 16, 2005 05:10 PM
