Civic Type R transmission! +flywheel and CM clutch
I recently sploded my b16b engine and am in the process of parting it out. I want to sell these all together I'm not willing to separate.
This trans is from a 99' JDM CTR with factory lsd. The Exedy flywheel is probably 3 years old but the Clutch Masters stage II clutch was put in in Sept (less than 6k miles) and has not seen any dumps or drag strip time. Zero grinds on the trans ZERO!
$900 for it all. I would prefer pic-up over shipping but I'll work it out if possible. This is an incredible deal as is so please don't insult me by low balling and I don't want trades because I don't have a Honda anymore.
B16B (Hydraulic):
S4C (LSD)
1st: 3.230
2nd: 2.105
3rd: 1.458
4th: 1.107
5th: 0.848
Reverse: 3.000
Final Drive: 4.400
The transmission found in the Civic Type R is highly sought after and very rare. Its gear ratio's are identical to that of the B16A's but has a stronger limited slip and dual synchro's in 2nd, 3rd, and 4th gears. There is a break in the boss as seen in the pic but there is still threads to grab and should not create any problems.
B16B (Hydraulic):
S4C (LSD)
1st: 3.230
2nd: 2.105
3rd: 1.458
4th: 1.107
5th: 0.848
Reverse: 3.000
Final Drive: 4.400
Honda Bull
Transmission & Drivetrain
Jan 9, 2012 11:58 PM
2006, civic, clutch, cm, flywheel, fs, honda, identify, problem, sale, tranmission, transmission, transmissions, type
