My parking lights won't turn on.
Ok so I have a 2001 type r. My parking lights along with my running lights will not turn on from inside the car on steering column. But I think the wiring may still be good because they will blink when I turn the turn signal. I checked a couple fuses and they didn't seem to be blown.
I could really use some help.
Thanks
Thanks
Break out a multimeter and start testing, check voltage at the plug. If it's there, it's the bulb (one of them is a two filament bulb, so the low side could be dead, it would blink fast then), if there's not voltage with the switch on, you'll need to start working your way through the system.
I've had fuses like that also, break was right on the ridge in the plastic so visually very difficult to see.
Doc Days
Honda CR-V & Element
Jun 1, 2017 09:05 AM
vi3tzkidd
Sep 27, 2009 12:21 PM
