Can I use this proportioning valve?
I noticed that Honda's prop valves have both the front and rear running to it. Seems odd since the rear is all that should be controlled unless Honda wants to control the front as well.
What's the big deal? I'm really wanting to know what Honda does differently in this area.
P.S.- This may be going onto a 2000 DC2.
When you press the brake pedal, fluid need to be routed to all four corners. If it flows to the rear more than it should, then they lock up before the front does it's job and vice-versa. IMO, Stick with what the Honda engineers designed.
I finally found that Honda uses what I think is called a diagonal flow (or something like that) braking system. Perhaps i'm missing something. I just want simple. I'm tired of looking at a jungle of brake lines under my hood.
Have you seen the brake line tuck thread? Put the prop valve inside the car. You will only then see the two lines coming off the MC. Pretty clean.
Yeah, the Honda designers were pretty sharp, but the biggest question is whether I really need such an exhaustive setup (OEM Honda). If something more simpler works just as well, then perhaps I should go that route. Lastly, and most importantly, the best overall question is whether the proposed setup will equal the performance of an OEM Honda proportioning valve?
I'm not questioning the quality of the Honda engineers' solution to the problem. I'm just questioning whether the same can be done with a simpler proportioning valve setup versus their proportioning valve setup.
oem is diagonal split, after market is front/rear split. Look for the documentation of the prop valve on wilwood's site. I believe you will need 2 adjustable prop valves.
I wasn't clear. A single after market prop valve is meant for cars with front/rear split. Some cars have diagonal split, some cars have front/rear. For cars with diagonal split, you need 2 after market prop valves to control the front/rear brake bias.
Cool. Thanks man.
crower
Nov 15, 2015 05:59 PM
2000, accord, adjustable, aftermarket, brake, brakes, designed, honda, hondatech, prop, proportioning, s2000, tuck, valve, wilwood
