Attn: GS-R Owners (Part II)
Old Sep 13, 2002 | 11:19 AM
B18Redline's Avatar
Default Attn: GS-R Owners (Part II)
What's the highest you would go on a GS-R with stock internals and no rev limiter.
I usually take it to 8300 rpm.
Thanks
Old Sep 13, 2002 | 11:28 AM
metal-x's Avatar
Default Re: Attn: GS-R Owners (Redline07)
8100 max
Old Sep 13, 2002 | 11:30 AM
Acronym's Avatar
Default Re: Attn: GS-R Owners (metal-x)
yeah no higher then 8100rpm
Old Sep 13, 2002 | 12:50 PM
neo1z's Avatar
8100 max
there really isnt any point in going higher...you dont make more power up there.
Old Sep 13, 2002 | 01:11 PM
mattL's Avatar
if you want to be aggressiv you could take it to 8400, bottom end and valves can handle 9k, but the valve springs arent stiff enough to rev that high
Old Sep 15, 2002 | 10:38 AM
TimoneX's Avatar
New User
Default Re: Attn: GS-R Owners (mattL)
I too don't see the point. Why risk it if there's no power gain up there?
Old Sep 15, 2002 | 12:16 PM
vteg's Avatar
New User
Default Re: Attn: GS-R Owners (TimoneX)
It is possible to get faster acceleration times by shifting while out of the engines power band. As long as you are making more torque at the wheels than the next gear you will be faster. This could be beneficial if you have a shorter FD or tranny with shorter gears also.
Old Sep 15, 2002 | 01:51 PM
B00ST2nR's Avatar
Default Re: Attn: GS-R Owners (neo1z)
8100 max
It depends on what you have. For example, I still make power passed 8300rpm and keeps going.
Old Sep 15, 2002 | 02:09 PM
acatak's Avatar
Default Re: Attn: GS-R Owners (Skunk2nR)
the fuel cut-off is at 8200 right???
Old Sep 15, 2002 | 02:51 PM
Q-OnE's Avatar
Default Re: Attn: GS-R Owners (acatak)
i tend to shift at 8200. everytime i race thats where i shift out.
Old Sep 15, 2002 | 04:06 PM
PoW3l2BaN's Avatar
i speedshift at 8200 rpm's....so basically..i rely on the rev limiter to keep me safe...you wanna keep the rpm's high because you want vtec-to-vtec shifting...i know its bad for the tranny, but it reduces your E.T.'s and peeps give you props when an all motor gsr with very few bolt-ons smashes on turbo hatchbacks boosting at 10psi.
Old Sep 16, 2002 | 11:59 AM
TimoneX's Avatar
New User
Default Re: Attn: GS-R Owners (PoW3l2BaN)
I think everyone here understands that shifting as high as possible is beneficial whilst attempting to remain in Vtec. The question was about increasing redline on stock internals, and again I cannot see the point. If you did increase it and nothing blew up(for awhile), you'd still slow down since the stock head runs out of breath before readline and output falls. I can see no way it's worth the risk. Change the cams and that situation changes, but the stock springs and retainers would still be a liability if you boosted redline.
Mo_Spec
Jun 8, 2011 09:40 PM
Mr. DeOro
Aug 16, 2009 04:55 PM
gsrt
May 11, 2007 06:32 PM
PAndADc2
12
Jun 5, 2005 01:17 PM
mdj_ge
Oct 8, 2004 12:02 AM
