Tires for EX Sedan (split from ITR topic)
I don't have an "R" but since this topic is relatively fresh discussing a tire I currently have, I wanted some advice.
I currently have 205/40/16's KDW's on my 96 ex sedan. I currently have the setup for sale. My new setup will be same size rim but .5" wider. I've had my KDW's on for the 4 seasons here in CA that happen all at the same time. LOL. And they have held up well. The only thing is I'd like to try a new tire. Something a little less noisy but w/ = perf. in a taller 205.45.16. I love spirited daily driving and the KDW's have been excellent for this. Price is not a big deal, but I'd like to keep it reasonable in the event I am unsatisfied and have to re-sell.
open to all recommendations.
Thanks In Advance.
Thanks In Advance.
Is your '96 EX Sedan an Accord or a Civic? I'm going to assume it's a Civic based on the tire size.
The '96 Civic EX Sedan came from the factory with 185/65-14 tires. The best matching 16" tire sizes are 205/45-16 and 215/45-16. 205/40-16 is too small; that's a good 16" size for older Civics (as well as '96 DX and hatchback models).
Based on what you've stated, I recommend the Yokohama S.drive or Fuzion ZRi, in 205/45-16. Both are very good summer tires, not terribly expensive either (both $90/tire at Tire Rack, less the $10/tire rebate on the Yoko).
Yes your assumption is correct. I own a 96' civic ex sedan. As I've read around, I came to the conclusion that 205/45/16 would be best new tire size. As you recommended. Will this still hold true if I were to do a engine swap in the future? More than likely b-series.
also I will be raising my car for a various amount of reasons.... 1 being sidewall height of the new tire. 2 oem accessories and 3 lastly new rim & tire dimensions.
what would be the biggest benefit going w/ a 215 vs a 205? tire life? fuel efficiency? braking efficiency? price? " traction " ?
and thank you for the advice you have shared.
The big differences are going to be in tire availability and price. The S.drive and ZRi in 205 (what I recommended) are going to give you better performance than comparable tires in 215 (such as the Dunlop Direzza DZ101) - not because of the difference in treadwidth, but because they are better tires.
If you wanted to get a stickier tire than the KDW, you could consider the Bridgestone Potenza RE-11 in 205/45-16 or Kumho Ecsta XS in 215/45-16; however, they're a lot more money than the S.drive and ZRi, and won't last as long as the KDW, which is why I didn't mention them - it seemed like you were looking for value as well as performance.
After I spend some time refurbishing my rims arriving tomorrow, I'll probably go w/ the S.Drives. I'll definitely report back.
for $460. OTD.that includes state tax. Mounted, life time balance & rotation from a "well-known" tire dealer. I skipped the protection plan do to what I view as my price "savings." In the event of catastrophe I pretty much saved enough to replace a tire. Once my rims return from powder coating at the end of this week approaching, I will take them in and get them installed and report back periodically w/ my personal seat-time review.
tranjq
Aug 27, 2008 08:27 AM
