Swap starts then dies
Hey HT,
Just did a fresh rebuild on a GSR block with a few goodies in it, swapped it in last night and tried to fire it up. It starts, revs for a second then dies immediately. The fuel pump is priming, the timing is dead on, i checked all plugs and grounds, I just cant find a thing wrong that would make it not run. Its as if its not getting fuel through the injectors besides when it first primes with ignition power.
A little background on this is the ECU is tuned to a LSV turbo setup i had a few months ago on 680 injectors. I now have stock injectors and a small NA build. I have NO CEL's, no vaccum leaks, nothing. Im lost. This is the 7th swap and build i have done in this car by myself and have never had a problem such as this.
Any ideas out there? Ask as many questions as you want and ill answer what i can.
If you trying to run 240cc injectors with an ecu tuned for 680's it's not going to happen. To idle with 680's requires a short pulse width. Trying to make the smaller injectors run on that short p w = no fuel. Get it retuned for your set up or try a stock ecu.
x2!
Stock FPR? Fuel pump?
x2!
Try a stock ecu
Try a stock ecu
Its a stock ECU and stockinjectors. I thought it would at least idle, but guess im wrong. im borrowing a stock ecu tonight to see if it will run.
Then give us a reading..
What about fuel pump? is that stock also?
FPR is fine so im banking on it being the ECU and injector size difference. My buddy is going to run by so i can borrow his ecu out of his 92 CX hatch...lol it should at least start.
I Like Hondas
May 30, 2008 02:11 PM
BUSAFREAK
Jun 25, 2001 09:50 AM
