Suspension & Brakes Theory, alignment, spring rates....
energy suspension help
Old Jun 9, 2010 | 07:48 AM
Joon Joon's Avatar
Default energy suspension help
so i put energy suspension bushings on most of my suspension parts... im putting a mugen 26mm front and rear sway bar.. i found the part number for the front d bushing for the front sway bar but cant find a 26mm dbushing for the rear... im also looking to add poly bushings for the endlinks for the front and the bushings on the rear sway bar where it connects to the endlinks.. could someone help me out and let me know which ones i need.. i emailed energy suspension and they just said look at the application guide which i have and cant find anything..
recap
have mugen 26mm front/rear sway
found part number for front dbushing
need part number for rear dbushing
need part number for front endlink bushings
need part number for rear sway bar bushing where the endlinks connect to it
edit: this is for an eg si/ej1
Old Jun 9, 2010 | 07:19 PM
Joon Joon's Avatar
Default Re: energy suspension help
so i found this image... looks like the front dbushing for an em1 will work for the rear.. could anyone confirm that the bushings for the front will be the same as the rear??
Old Jun 12, 2010 | 08:47 PM
Joon Joon's Avatar
bump... any input??
Old Jun 12, 2010 | 11:04 PM
98civdx's Avatar
Master Detailer
i took a look at my bushings, (stock, not es) and they both are flat on the bottoms, and seem to be the same other then clear differences. Ill see if i can figure out for sure.
It may just be one of those things, where you are the only person on here to try such a thing, you may find you might just have to bite the bullet and try.
I understand you want poly, but have you checked to see if mugen sells these?
Old Jun 26, 2010 | 12:05 AM
makindue84's Avatar
Originally Posted by Joon Joon
so i put energy suspension bushings on most of my energy suspension parts... im putting a mugen 26mm front and rear sway bar.. i found the part number for the front d bushing for the front sway bar but cant find a 26mm dbushing for the rear... im also looking to add poly bushings for the endlinks for the front and the bushings on the rear sway bar where it connects to the endlinks.. could someone help me out and let me know which ones i need.. i emailed energy suspension and they just said look at the application guide which i have and cant find anything..
recap
My friend knows how to install that poly bushings. If you wanted, I can refer him to you. :D
Old Jun 26, 2010 | 11:33 AM
allmotorlsbaby's Avatar
I think a company called prothane spelling on that one sell universal d bushings. Check em out or maybe hardrace
Old Jun 29, 2010 | 10:21 AM
makindue84's Avatar
ya prothane makes some quality stuff too, I used to use them for my old DSM motor mounts and control arms...good luck
lunatictokyo
Aug 21, 2014 05:59 AM
Joon Joon
Suspension & Brakes
10
Oct 12, 2007 05:46 PM
vadersi
Dec 8, 2004 08:03 AM
Leimokei
Jul 31, 2002 08:44 PM
wakaru
Jul 20, 2002 03:39 PM
