90 si b18a1 in it subframe cracked what should i do
i have a 90 ef si wit a b18a1 in it and i just realizied that my subframe is cracked alittle bit near the rear motor mount what should i do just weild it?also my tranny is very close to the frame and altnertor so does any one know how much i got to notch it or any other ideas need help
you really need to enforce that. I'm not sure how bad it is without a picture, but a small crack under the all mighty honda power can lead to an engine on the floor going freeway speeds.
ill see if i can put a pic on but its a small crack in two or three spots the engine moves when i start it not much but moves u think i should still weild it
been there done that.. u have to replace your subframe!! they are very weak on the civic/crx.. what you have to do is get a da integra subframe and sway bar with brackets an ur good to go.. good luck
