Help!!!!
Old Sep 13, 2002 | 10:37 AM
CimorelliCRX's Avatar
Default Help!!!!
cant get hub bolt off of my axle i need to replace it what is the easiest way to get it off we have tried everything that we can think of maybe someone has an idea we can use
thanks
Old Sep 13, 2002 | 10:46 AM
takeheed's Avatar
Default Re: Help!!!! (CimorelliCRX)
im assuming the car isnt jacked up causing the wheel to spin and that little tab is knocked back out so it can break loose. take a long metal pipe and put it over your ratchet to give you extra leverage.or if you have air tools,you can go that route.or take your jack and raise it up so its even with the nut, put a long extension on you ratchet,put the socket on the nut rest the extension on the jack so it will keep the soket sqare with the nut and jump on that bitch till it breaks loose!! good luck!
Old Sep 13, 2002 | 10:49 AM
keithv's Avatar
Default Re: Help!!!! (adamjoey)
if you have a breaker bar and a long pipe (if you have some weights lying around, you should have a nice 6" steel pipe) to break that loose.
i use air tools only on axle nuts...
Old Sep 13, 2002 | 10:58 AM
Default Re: Help!!!! (breaka_1_9)
we have done that but it didnt work so i guess we are gonna have to tow it to a shop to get it impacted off then thanks though
Old Sep 13, 2002 | 11:33 AM
Urban Business
Guest
Posts: n/a
yeah rule #1 w/ axle nuts. hit up the gass station on the way home and have them loosen them and hand tighten them for you
Old Sep 13, 2002 | 11:34 AM
Mugen Dom's Avatar
Default Re: Help!!!! (TorteX)
buy a good impact gun
mrdeadman
May 14, 2009 10:00 AM
SLeePeR-STaTuS
19
May 15, 2007 01:14 PM
91-lsvtecsi
Suspension & Brakes
Oct 18, 2005 07:57 AM
projecthybrid04
Sep 29, 2002 05:35 AM
FUP23
31
Aug 2, 2002 12:20 PM
