My CRX won't start
My crx does not always start, when the engine is cold i have to spend a few mins turning the key to start it(sometimes it won't start at all) but when I drive it for awhile and the engine warms up it starts on the 1st try. what do I need to do to fix it? Somebody please help!!
Well if you think its the fuel pump then when it happens listen for the pump to turn on it will run a couple seconds after you turn the key on but not cranking it will be a small hum. If it dont then that could be your problem.
