ZEX wet nitrous kit $300
Zex 4-6 cylinder EFI wet nitrous system 55,65 and 75 shot, universal kit that is designed to work safely on stock type engines but is also engineered to perform flawlessly on highly modified turbocharged and supercharged combinations. It is a simple, 2 hour installation. comes with zex nitrous managment unit, nitrous lines, tap for threading your intake tube for installing nitrous nozzle, engagment switch, hardware, installation instructions, i also purchased a purge kit and saftey blow down tube which is included, i only have the jets for the 75shot the other ones are missing because they are the size of peas, they can be purchased through zex for like 2$ each. the kit was partially installed but NEVER used, the nitrous management unit wires have never been cut, spliced or stripped. i mounted the managment unit and ran the nitrous lines... i needed some extra money so was in the processed of removing the kit but my car was stole with the bottle still in the truck, this is a complete kit minus the bottle
this kit has Active Fuel Control™ monitors bottle pressure & adds or subtracts enrichment fuel for maximum engine safety & power
also this kit has an engagment switch the switch turn on the system but the nitrous is actived when you give it full throttle that means as long as you have your foot to the floor your spraying nitrous for as long as you want, i do not want you to be confused with what you may have saw on the fast n furious you do not hit a button and get a small burst of nitrous
i paid 650$ for the kit 55$ for the blow down tube and $120 for the purge kit... over 800$ total and im selling it for 300 thats a good deal
EMAIL ME AT MATTCAMPY19@YAHOO.COM OR SEND ME A MESSAGE FOR PICTURES OR QUESTIONS
