CA FS: Turbo 2000 Integra DVP GSR 439WHP/203TOR
Old Jun 8, 2010 | 02:09 PM
actionanh's Avatar
Default FS: Turbo 2000 Integra DVP GSR 439WHP/203TOR
For Sale: 2000 Integra GSR 439WHP / 302WTQ
CLEAN TITLE
116,XXX miles
NON-SMOKER - ORIGINAL OWNER
Dark Violet Pearl - 1 of 300 - Exclusive Color for 2000
Maintained Very Well and On Time
Smog Free until April 2012 - BUY BEFORE JULY 2010 and you won’t have to smog it, since it was done in April.
439WHP / 302WTQ Tuned at Redzone Performance DYNO sheet up later tonight.
The ONLY Bad: Oil leak from the oil pump, Oil Pump needs to be resealed to the block. THIS IS AN OEM HONDA OIL PUMP!
Contact:
NO PMs, if this is still up, it’s still for sale.
408 605 9684 (Voicemail is OK, Text is better)
TEST RIDES for people with CASH IN HAND ONLY.
vote4anh@gmail.com for all you shy people.
PRICE: $7,000 FOR EVERYTHING or lower depending on the parts taken off i.e. wheels, brakes, etc.
NO TRADES! ONLY CASH! NO TRADES! WE DON'T WANT YOUR TRADES, BIKES, AND PAYMENT PLANS!
Engine:
Original B18C1, NEVER BLOWN before, was built for Boost.
Block Sleeved by RS Machines
81.5mm Bore
Forged Wiseco 10.0:1 Pistons
Forged Eagle Rods
Original GSR head - Original Ports
Portflow Valve Springs
Portflow Retainers
Skunk2 Stage 2 Cams
Evolution Time N Lock Cam Gears
Original GSR Transmission
Garrett GT3076R Turbo
Spoolin Performance Ram Horn Exhaust/Turbo Manifold
Spoolin Performance 3 Inch Closed Loop Downpipe
Tial 38mm Wastegate
Greddy Profec B Electronic Boost Controller
Motorola 2.5 Bar Map Sensor
Spoolin Performance Intercooler - 24x9x3 - Sprayed Black
Spoolin Performance Charge Piping
Synapse BOV
Spoon Sports 70mm Tapered Throttle Body
REV HARD Intake Manifold
Injector Dynamic 1000cc Saturated Fuel Injectors
Walbro 255 LPH High Pressure In Tank Fuel Pump
WILL NOT COME WITH TYPE R MUFFLER
3 Inch Exhaust with 3 Inch Straight Thru Vibrant Performance Muffler (PRETTY QUIET!)
Spoolin Performance Oil Catch Can hooked up to Custom Vented Valve Cover
JVT Half Radiator with SPAL fan
MSD Coil SS
MSD 6A
Crome Chipped OBD1 P72 ECU
RZ Spec Clutch
Fastline Stainless Steel Braided Clutch Line
OEM Oil Pan Tapped for Oil Line with Fastline Oil Pan Baffles
AEM Meth/Water Injection
Exterior:
OEM Acura Type R Front Lip
5000k HIDs
S2000 Antenna
JDM Window Visors
Suspension / Brakes / Wheels / Tires:
SSR Competitions - Gunmetal with Polish Lip - 16x7 +4# Offset
Falken FK452 - 225/45/16
WILL NOT COME WITH TEIN COILOVERS/EDFC - WILL COME WITH OMNIPOWER FULL COILOVERS
ASR Rear Subframe Brace
Skunk2 Rear Sway Bar
Custom Rear Lower Tie Bar - Welded onto Rear Subframe
Ingalls Camber Kit
12.2 Inch Front Rotors With Wilwood 4 Piston Calipers
Fastbrakes 11 inch rear rotors
Stainless Steel Braided Brakelines
Neuspeed 4 point Front Strut Bar
DRIVE Brake Master Cylinder Brace
Interior:
2000 Integra Cloth Seats
Autometer Cobalt Gauges - OIL PRESSURE, WATER TEMPERATURE, BOOST
PLX Air Fuel Gauge
Pioneer DEH5200 Headunit
Fastline Road Race Shifter
Circuit Hero Shift ****
Old Jun 8, 2010 | 02:13 PM
Mizery27's Avatar
Default Re: FS: Turbo 2000 Integra DVP GSR 439WHP/203TOR
do you have any pics of the dyno sheet or anything?
Old Jun 8, 2010 | 02:34 PM
actionanh's Avatar
Yes, I'll get it up by tonight
Old Jun 8, 2010 | 03:17 PM
HaNgTiZZy's Avatar
legit glws
Old Jun 8, 2010 | 03:27 PM
built_4g63's Avatar
Nice price. Bump for boosted teg
Old Jun 8, 2010 | 05:41 PM
srt4mike's Avatar
That looks ridiculously nice!! GLWS
Old Jun 9, 2010 | 03:04 PM
actionanh's Avatar
up
Old Jun 9, 2010 | 04:29 PM
psi2high's Avatar
Wow thats a steal. Good luck with the sale.
Old Jun 9, 2010 | 06:59 PM
drive4aliving's Avatar
I can personally vouch for this car. i've been around this car since day one. very well taken care of. mods have been choosen extremely wisely. car was built to be functional, reliable and fast.
the owner does not go on forums
if you have any questions about the car itself, please feel free to ask me
this is truly an amazing deal.
Old Jun 9, 2010 | 07:32 PM
fv8s's Avatar
holy shifter ****
Old Jun 9, 2010 | 08:52 PM
Paste's Avatar
Loved
Originally Posted by fv8s
holy shifter ****
Old Jun 14, 2010 | 03:01 PM
CORRECTION: 303 WTQ not 203
Old Jun 14, 2010 | 03:46 PM
AGPDB2's Avatar
7g's.... seems kinda low. What's wrong with it?
Old Jun 21, 2010 | 08:45 PM
actionanh's Avatar
leaks oil and needs a new seal, and we need a quick sell!
Old Jun 22, 2010 | 08:06 PM
Mr.Spec's Avatar
this is a great car to buy. the owner takes good care of it and if you drive it, youll see how well the setup runs, traction, fast spool, handles and brakes extremely well !
wrxking108
Jul 6, 2014 05:30 PM
bgruver
Jul 6, 2007 06:22 PM
jArceo
Jul 14, 2002 12:28 AM
