Installing cams...question?
I talk to a shop about tuning my car once I have finished installing my stage 2 cams. The shop told me to make sure I degree down my cams. Is That really necessary? Couldn't they just tune it using the adjustable gears to find a where the car likes it?
They can do that in conjunction with the partial and WOT tuning of the car through your management. Please be aware that there will be an increase in tuning costs that may have been given to you as an estimate. They also want to make sure that you're responsible for the piston-to-valve clearances that you had when installing the cams. If there were some "quick degree" points to those cams, now is the time to use those so you can get to the tuner safely. If not, best to trailer the car there.
I'm stalling the stage 2 skunk2 cams so it would propabley be best if I take it on a trailer. I know for a fact that it will not idle well. Do you think it would be ok to drive to the shop or no?
I'm assuming you're gonna be running the Tuner series stage 2 cam?
Claying your motor will tell you how much clearance you have from the valve to the piston's valve relief.
I used the quick setting that Skunk2 gave me, and drove it like that to my tuner that day. Brian told me that its +4*I, 0*E and I found out from All_Motor(user herer) that it's actually the other way around(0*I, +4*E). All_Motor also said that I might've bent some valves but my engine is running fine though. I'll get my engine leakdown test done soon here though. But now my tuner had my quick settings at -1*I, +3*E. Just make sure there's 3-4 Degree separation between the two cam gears so there won't be any tight V2V clearance.
Where did you have your cam gears set at before you got the motor started up?
Lol. No seriously I'm not kidding. Just because I'm a moderator doesn't mean I know everything in the world.
I understand adjusting the cam gears, I just didn't understand why it's called something else.. You all got me with that terminology.
I'm here to learn too.
So some cams need to be degreed in just so you can start the engine, etc.. They can't be set at 0,0?
Not all cams use oem centerline.......
A train
24
Mar 10, 2005 10:33 PM
