Is synthetic really better?
Old Sep 13, 2002 | 10:01 AM
Dodger2940's Avatar
Default Is synthetic really better?
I just went to Wall-Mart to buy oil. Got there and saw that a 5 quart jug of Castrol GTX on sale for $7.99, I went there looking to get the Cartrol Syntec which was 4.99 a quart. My question is are the sythetic oils better than the regular oils?
Old Sep 13, 2002 | 10:45 AM
Tofurky's Avatar
Default Re: Is synthetic really better? (Dodger2940)
every answer is going to be different
Old Sep 13, 2002 | 01:23 PM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: Is synthetic really better? (Ruckus138)
Do a search in the ITR forum. There is a REALLY TECHNICAL debate, with some guys that know their **** when it coems to oils (Both synthetic and non). It might be archived now but its a great resource.
Old Sep 13, 2002 | 02:43 PM
Dodger2940's Avatar
Default Re: Is synthetic really better? (Apex i ITR)
Old Sep 13, 2002 | 04:25 PM
splitime's Avatar
As far as specifically for hondas i dont have an answer, to new to playing with them. But a few years back a work for a company that specializes in Tribology, the study of lubricants. They do research for the air force and major oil companies with regards to greases and oils. They do heat tests, cold tests, shearing, force etc.... they test for it all. The one thing i remember from being there is they mentioned that running a synthetic like Mobil 1 is the best bet for longevity. As far as performance i have no clue, but I run it. Back then i coulda gotten the plots from tests run to prove this, but that was then.... oh well. Anyway, just my .02 from a past experience.
Old Sep 13, 2002 | 05:08 PM
EVIL Hx Coupe's Avatar
Default Re: Is synthetic really better? (splitime)
I run Valvoline Synthetic, I don't know whether synthetic is better than the other oil but I feel safer. Like the other guy said I've seen many debates about this and there is always different opinions.
Old Sep 13, 2002 | 05:12 PM
deepnite's Avatar
Default Re: Is synthetic really better? (Boost Pressure)
i began using Mobil 1 in my wifes volvo nearly 200k ago..its got over 300k on the motor now and doesnt burn a drop of oil..i change the oil every 5k..and all my cars now use Mobil 1 10w-30 regardless what the factory manual recommends
Old Sep 13, 2002 | 06:00 PM
fsck3r's Avatar
Default Re: Is synthetic really better? (deepnite)
I found out that if you have an old motor and the person who had it only got Pertol oil changes, if there is and bad seals the synthetic WILL find the bad seal and leak like a bitch....at least mine does
Old Sep 13, 2002 | 07:02 PM
johnzm's Avatar
Default Re: Is synthetic really better? (fsck3r)
every answer is the same.,...
read this
https://honda-tech.com/zerothread?id=163845
Old Sep 13, 2002 | 09:13 PM
Koori's Avatar
Default Re: Is synthetic really better? (johnzm)
Valvoline and Mobil1 are great in both synthetic and petroleum bases.. I just used regular Mobil1 5w-30... But I also change my oil whenever I'm very bored.. No oil is in my car for over 3000, usually change every 2K or sometimes less if I've been running hard.
Old Sep 13, 2002 | 09:29 PM
senpai's Avatar
Default Re: Is synthetic really better? (Hadji)
I got 5qt Mobil1 tri-sythetic for $18 !!! I bought (2) for the hell of it!
Agito
13
Jan 18, 2008 04:34 PM
DohcSide
20
Mar 9, 2005 02:51 PM
MiguezVTI
15
Nov 17, 2004 01:02 AM
JMVenturello
Mar 23, 2004 03:03 PM
Jet Phi
Sep 16, 2002 02:18 PM
