TAIL LIGHT FUSE KEEPS POPIN FROM BAD MOUNT
Old Jun 8, 2010 | 03:32 AM
jbrokos307's Avatar
Default TAIL LIGHT FUSE KEEPS POPIN FROM BAD MOUNT
ok so i just found i have a bad trans mount in my ed7 when ever i go to take off and the motor shakes the dash lights and brake lights and runin lights cut out and fuse #8 keeps takin a poop on me anyone ever had this issue it stays on for a few mins but asoon as i give it a little to much gas while movin poop it goes out i need to fix this asap dont need a inspection ticket
Old Jun 8, 2010 | 05:50 AM
Jockone's Avatar
Default Re: TAIL LIGHT FUSE KEEPS POPIN FROM BAD MOUNT
The fix is obvious,if the mount is causing the problem then replace the mount.
It sounds like too much movement in the engine and you could be pinching a wire somewhere.
Old Jun 8, 2010 | 05:56 AM
~sp33~'s Avatar
EFB055
Just fix the mount. With your engine flopping around in there, it's probably causing stress on a ground wire or grounding out a power wire, who knows.
CRX_Banned
Jan 3, 2008 08:35 AM
vettman
Jul 16, 2005 12:30 AM
SYTFU Tommy.
Jul 30, 2004 02:16 PM
balistic CRX
Dec 27, 2001 04:37 AM
