IL 2004 White Evo 8 For Sale -- Mean and Clean 400whp Street Car
Posting this for my buddy Yuta, this thing is immaculate and very well rounded... I believe he said it will most likely be coming with the stock wing on it, but I'm sure he can be worked with as far as any parts go.
04 Weightless White SSL Package Evo 8. Just over 40K miles. Mobil 1 Oil changes every 3000 miles with genuine Mitsubishi filter. I am the original owner ever since bought brand new back in 2004. The car is in very good shape, no accidents or any damage. I have taken very very good care of it. Always garaged and only seen winter once (first year I had it). This car is just amazing overall. This car is simply one of the best cars I've ever owned/driven. The whole labor work on the car was done by me other than the tuning and some fabrication. This car has put down 400hp/330ft.lbs. torque on pump gas at 24 psi. Tuning was done by Mr. Chris Black of AMS Performance. I'm asking $27K obo for the car. Depending on how low the price goes, I will be removing parts if that is the case. I will also consider trading the car plus cash on your side only if its a S14. If there's anything else that you wanna kno about the car, call/text to 224-578-1516. Name is Yuta. Now here's the list of what's in it.
- AMS intake manifold
- GT3076R turbo
- AMS FMIC
- AMS UICP
- AMS LICP
- APEXi N1 catback
- Tial 44mm external wastegate
- HKS SSQV Bov
- RMR hood scoop
- Version Select front aero bumper w/ canards
- C-West Replica sideskirts
- APR full carbon rear diffuser
- Sparco Replica harness bar
- Buddy Club Racing Spec coilovers
- Gruppe-S triple gauge center pod
- HKS RS Intake
- Cusco oil catch can
- Carbign Craft carbon spark plug cover
- Zaklee clear cam cover
- Buddy Club 272 cams
- HKS adjustable cam gears
- AMS poly motor mounts
- Stainless steel clutch lines (upper and lower)
- Exedy twin plate clutch w/flywheel
- Stainless steel brake lines
- Performance Friction Carbon Metallic Z brake pads
- Defi D-Gauges
* Boost
* Water Temp
* Oil Temp
* Oil Press
- AEM Wideband gauge
- Greddy Profec B Spec II boost controller
- Greddy Turbo Timer
- Helix Test Pipe
- Helix downpipe fabricated
- Full Race replica turbular manifold
- 255 Walboro fuel pump
- AMS fuel rail
- 780cc fuel injectors
- Buschur Racing bored out throttle body
- Samco Radiator hoses
- Ralliart thermostat
- Shifter bushings
- AMS small battery
- ARP Headstuds
- Cometic Head gasket
- Carbign Craft carbon radiator shroud
- Enkei RPF1 (White, 17x9 +22 offset)
- Evo VII JDM Tail lights
- Upgraded HID bulbs (8000K)
- GT3076R turbo
- AMS FMIC
- AMS UICP
- AMS LICP
- APEXi N1 catback
- HKS SSQV Bov
- RMR hood scoop
- HKS RS Intake
- Defi D-Gauges
* Boost
* Water Temp
* Oil Temp
* Oil Press
- Helix Test Pipe
- AMS fuel rail
- Shifter bushings
- AMS small battery
- ARP Headstuds
maxum17ft
Sep 9, 2011 04:44 PM
dunkd
Jan 9, 2010 09:14 AM
WhiteOnRice
Apr 4, 2008 06:52 AM
GLWS
