temp. past High...help
Old Jun 7, 2010 | 10:30 PM
akshn1's Avatar
Default temp. past High...help
so i put a brand new radiator in my ef today..new coolant etc....i also took out the cluster to paint the needles orange.......when i put the key in ignition to second click the temp just raise to H THEN PASSES IT.....i try to adjust it while the car was on (move the needle)..when car is off the needle is at cold...so i drive the car and it stay on HIGH but not over heating..never happend with other radiator? any body help?
Old Jun 7, 2010 | 10:38 PM
AndThenYouSay's Avatar
Default Re: temp. past High...help
Grab a multi-meter, pull the connector off your temp sensor and see if its in spec.
BTW, about how much should a new rad cost me? mines hissing pissing everywhere
Old Jun 7, 2010 | 10:57 PM
~sp33~'s Avatar
EFB055
It wouldn't have anything to do with the radiator. Something's happened when you pulled the cluster out.
Old Jun 7, 2010 | 11:12 PM
akshn1's Avatar
try the radiators off ebay...cost 48$ shipped..ive had them before and never had a prob.............
i even disconected the battery and ecu..just incase there was a glitch..idk...but still the same
......maybe a fuse or relay???
Old Jun 8, 2010 | 01:38 AM
~sp33~'s Avatar
EFB055
So does the temperature spike as soon as you turn the car on, or does it slowly move up beyond H?
If it spikes then it's definitely an electrical fault. If it takes about 5 minutes or so to get high than it could be a blockage in the radiator or trapped air from a poorly bled system.
Old Jun 8, 2010 | 03:46 AM
netfreak's Avatar
Did you by chance remove the needles from the cluster for the painting?
Old Jun 8, 2010 | 10:34 AM
akshn1's Avatar
no i didnt not remove them just masked the up with tape.....
Old Jun 8, 2010 | 10:37 AM
akshn1's Avatar
takes like 30 seconds then slowly go up past h
Old Jun 8, 2010 | 11:11 AM
akshn1's Avatar
cold..not started
after 30 seconds of being on....wtf???
Old Jun 8, 2010 | 05:29 PM
~sp33~'s Avatar
EFB055
Is the radiator cap hot? Sounds electrical though, i don't think it's possible to overheat a car in 30 seconds, unless you didn't have any water in there, and if that was the case, the car wouldn't read hot. Do you have an online manual you can troubleshoot from? They're quite handy when tracing circuitry.
Old Jun 8, 2010 | 05:41 PM
zzzjoe's Avatar
I replaced the radiator on my Civic refilled it, started it up, drove down hill 3 blocks, at the stop sign my temp gage was up to the H. It turned out to be air in the system once I got it out it went back to normal
Sel ven
Honda Civic (2001 - 2005)
Dec 8, 2018 11:36 AM
1991crx16
14
Jan 26, 2011 01:47 PM
cjwarren4dacord
Nov 27, 2010 04:13 AM
MPALUGHI
Aug 15, 2005 12:40 PM
One Bad GeeSeeR
Dec 4, 2002 05:08 AM
