Radiator support..
Old Jun 7, 2010 | 10:16 PM
phrenzykEG6's Avatar
Default Radiator support..
The previous owner of my hatch got in a small front end, and the radiator support is kinda damaged and is throwing off the alignment of the whole front end, as i am trying to clean up the car and make it look half way decent, my question is:
Is the radiator support bolt on or does it have to be welded, I've found some replacements on eBay and I'm quite curious on if this is a DIY job... Thanks a million in advance for any feedback.
Old Jun 8, 2010 | 12:28 AM
ek9b's Avatar
Default Re: Radiator support..
it's spot welded on so you have to drill the spot weld's to take it off and then you can bolt the new on good luck man
Old Jun 8, 2010 | 12:33 AM
Deetz's Avatar
Crazy Honda Guy
Big job, not a DIY
There must be quality welding as well as alignment. Good chance the car needs to go on a body shop rack to be pulled a bit to to line things up properly
Here's a shot of when my rad support was replaced
Old Jun 8, 2010 | 03:48 AM
EJ8-H22's Avatar
JUST REPLACE IT MAN
WITH NEW ONE
OR USED BUT IN GOOD CONDITION
Old Jun 8, 2010 | 04:29 AM
aha's Avatar
aha
Get it done the right way and take it to a body shop. if it has some front end damage the car is going to have something else tweaked.
Old Jun 8, 2010 | 05:23 AM
farfrumugen's Avatar
dont bolt it .....WELD IT.....
adam jeffery
97teggysc
Welding / Fabrication
Feb 12, 2013 04:30 AM
hectic947
Dec 12, 2010 02:59 PM
Boostn B20
Aug 21, 2008 02:27 PM
divisionskate
Nov 22, 2006 07:35 AM
