piston free play?
Old Jun 7, 2010 | 09:47 PM
itr1244's Avatar
Default piston free play?
i just pulled my head out to fix my oil leak.
while i was cleaning my piston up a bit i notice my pistons have free play . it can turn left and right a little bit. is this normal?
Old Jun 8, 2010 | 07:46 AM
ruffrhyder's Avatar
Default Re: piston free play?
Left and right as in timing belt to flywheel or header to intake manifold? Also, do you mean turn like rotate vertically or slide horizontally?
Old Jun 8, 2010 | 07:18 PM
95skunkedgsr's Avatar
i think he means that like it twist lol, as in he can turn it clock wise and counter clock wise if your staring down at it while it is in the car and still on the motor mounts ??
Old Jun 9, 2010 | 05:47 AM
95 integra's Avatar
More information, like are you spinning the piston from the top side or the rod from the bottom. Rod cap is installed and torqued? Sliding or twisting? How much play?
Old Jun 9, 2010 | 09:18 PM
itr1244's Avatar
yeah sorry i mean it twists
but it does take quite a force to do that while i cleaned the top of pistons but it didnt move that much just slight movement
ZCHondaCRX91
Engine Machining & Assembly
Feb 12, 2019 02:43 AM
mike93eh2
Dec 14, 2010 02:34 PM
nick91civicsi
Nov 11, 2006 11:06 AM
VtecbOi
25
Nov 1, 2005 06:43 PM
DirtySoda
Oct 13, 2003 08:10 PM
