Window completely off
Old Jun 7, 2010 | 09:39 PM
inaety's Avatar
Default Window completely off
Hello everyone, I am freaking out quite a bit because my window has just completely fallen off. It has dropped all the way into the door now. Even if I put it on the tracks, it still won't move because it's not "connected" to the motor. The motor still spins when I push the button but the window obviously won't move. What should I do? I really don't want to bring it to Honda over this but it's terrible since I can't drive anywhere for fear of theft or weather.
Thanks guys
Old Jun 7, 2010 | 10:00 PM
honda-junky's Avatar
Default Re: Window completely off
This happens to everybody. You are not alone.
Take off the Door Panel.
Search the bottom of the door panel for the missing bolts.
Roll the window regulator all the way down.
Get out your trusty 10mm socket.
Put the window back on the track. (by hand)
Re-insert the bolts through the window into the regulator. Tighten.
Its pretty simple and you will learn to do this all in less than 2 minutes. good luck.
Old Jun 7, 2010 | 10:04 PM
inaety's Avatar
Yeah, I have had to do that when it's fallen off the track before and it's real easy. But this time it's off the regulator. I guess I am gonna have to pull out the glass and look at the regulator? I'm not sure how to do that...maybe I could try just putting it on the old regulator to see if that's still good
Old Jun 7, 2010 | 11:07 PM
inaety's Avatar
bed time bump
Old Jun 7, 2010 | 11:17 PM
Deetz's Avatar
Crazy Honda Guy
Originally Posted by inaety
bed time bump
You are bumping this?
The regulator is held in by like 6 bolts, there is nothing to it. If it's still good, put the regulator back together, if not, buy a new one.
It's a common issue
Old Jun 7, 2010 | 11:43 PM
raidacaipo's Avatar
Yeah this annoys me too. We give them the answer and they still doubt us...
Old Jun 7, 2010 | 11:53 PM
EJ8-H22's Avatar
gl whith that sh@t
crxaddikt
14
Jun 21, 2011 11:32 AM
acc0rdf22
Oct 8, 2009 12:17 PM
Knightmare69
Apr 24, 2006 09:24 AM
DOHC_VTEC69
Feb 3, 2005 11:39 AM
pinoyboy204
Jul 30, 2003 06:17 PM
