no start,replaced dizzy and main relay...now what
92 civic turbo...does not start, it sat over winter(started fine) as i was working on repainting,then it lost priority. went to move it this spring..no start. tach does not bounce.
was suggested to replace the main relay(starter was not turning.) so then the starter works, now it would not start. cranks fine, i have 40 ish psi during cranking fuel pressure.
i have spark, it will pop every once and awhile. does anyone have the wiring diagram from the ecu to the dizzy wheel so i can check the wires?
my biggest concern is that my tach does not bounce or does it...i can't remember. my cluster's check engine light does not work.
anyone have any ideas on what else i could check? haynes manual is better as a last resort toilet paper then any trouble shooting.
thanks in advance
thanks in advance
No More Civic
10
Aug 27, 2002 09:35 AM
