13" woes.....
Old Jun 7, 2010 | 09:51 AM
H23_del_soul's Avatar
Default 13" woes.....
What's the deal with 13's? Is something wrong with running them, or is it the tire manufacturers just not putting out tires for them that makes them not worth running? I FINALLY found a good set and was planning on running them on my sol but I can hardly find any good tires. What's the deal guys?!?
Old Jun 7, 2010 | 02:37 PM
Default Re: 13 woes.....
Come on tire gurus.....
Old Jun 7, 2010 | 06:37 PM
TunerN00b's Avatar
The deal is that most new compact cars come from the factory with 17+" wheels, and even the subcompacts run at least 15" wheels.
In short, 13" wheels really aren't worth using any more.
I've got one car sitting on a set of 155/80-13 sized tires, which were nearly impossible to find even 5 years ago, and much more so today. The era of small wheels has passed.
Look on the bright side, at least your Del Sol has a very large selection of wheels available. My car uses a 4x95.25 bolt pattern...
Old Jun 7, 2010 | 07:21 PM
What the hell bolt pattern is that?!?
Old Jun 8, 2010 | 12:54 AM
bkindness's Avatar
Default Re: 13" woes.....
i don't figure out either
Old Jun 8, 2010 | 11:17 AM
TunerN00b's Avatar
4x95.25 = 4x3.75", from the days before metric measurements were common.
The Triumph Spitfire and GT6, the Lotus Elan, and the MGF (and possibly others) all use that pattern. My Spitfire came with 13"x5" 4x3.75" +0.5" (+13mm offset) wheels (and those were the "upgrade" over the previous years 13"x4.5" wheels).
Pretty much, unless I want to get a set of Minilites, I'm going to need to get something custom drilled to fit that car...
Old Jun 9, 2010 | 12:30 PM
nsxtasy's Avatar
H-T Order of Merit
It's been YEARS since they made any good street tires in 13" sizes.
Old Jun 10, 2010 | 08:43 AM
proshift's Avatar
Toyo makes a few in 13", like Proxies for example. Also Toyo has a high tread ware tire called a "Extensa" or something like that and then Kumho makes one and Michelin as well.
Old Jun 10, 2010 | 12:40 PM
msncml386's Avatar
i ended up having to get mine from sears
Old Jun 10, 2010 | 01:57 PM
TunerN00b's Avatar
Toyo's website doesn't list anything smaller than 15" for the Proxes 4 and the Proxes R1R, and nothing smaller than 14" for the Proxes T1R. The R-compound Proxes tires that do come in 13" sizes are not exactly street tires...
The Extensa is a rather crappy tire, is what I currently have in 155/80-13, and helps provide evidence for:
Good, being the operative word there.
Old Jun 11, 2010 | 08:50 AM
Well, looks like there going back up for sale then either that or to the scrap yard
Old Jun 11, 2010 | 08:59 AM
proshift's Avatar
Too bad you can't get the Yokohama A539's in North America
Old Jun 11, 2010 | 09:11 AM
proshift's Avatar
How about these Sumitomo's? http://www.tirerack.com/tires/tires....omCompare1=yes
Old Jun 11, 2010 | 11:37 AM
nsxtasy's Avatar
H-T Order of Merit
Even in countries where they sell them, they don't make the A539 in sizes that cars with 13" wheels would need, like 175/70-13 or 185/60-14.
They are cheap and they are available in 13" sizes. Their performance is not very good at all.
Old Jun 11, 2010 | 11:47 AM
These actually don't look all that bad.... Whats so bad about them? I know I can't auto-x in them, but other than that whats the issue?
Old Jun 11, 2010 | 12:33 PM
nsxtasy's Avatar
H-T Order of Merit
They just don't grip very well, compared to other summer tires. But it's your only choice; if you want them, get them.
yugisxrc
Dec 20, 2012 05:41 PM
bellinoracing
Feb 12, 2011 11:53 PM
exbauer
Midwest
Dec 9, 2007 04:18 AM
Phazetwo Mike
Honda S2000
Jul 8, 2005 07:22 PM
