Need help!! A/C compressor clutch questions
Old Jun 7, 2010 | 05:19 AM
SuperCivic's Avatar
Default Need help!! A/C compressor clutch questions
I'm working on a 2000 integra type R. Have a few questions. Is the AC compressor (denso) the same between years (94-01) and trim levels (LS, GSR, R)?? Are they interchangeable?
I looked through Delray acura's parts list and found that the ITR ac clutch kit is a different part number ending in P73-003 instead of other trim levels ending in P72-003. So this means the ITR has a specific a/c clutch kit??
I tried using a JDM OBD1 B16 compressor the other night and found that the compressor is exactly identical, but the pulley on the ITR is smaller in diameter and the clutch kit is just a hair different, meaning it wouldn't work.
Please don't answer unless you KNOW what you're talking about. Thanks.
Old Jun 7, 2010 | 05:32 PM
SuperCivic's Avatar
Default Re: Need help!! A/C compressor clutch questions
it appears that all compressors are the same from 94-01, all are denso. There are different brackets tho, and different pulley/clutch combinations. It appears that the ITR pulley and clutch are specific to the ITR. Can anyone confirm that?
Old Jun 10, 2010 | 05:46 PM
SuperCivic's Avatar
OK got my A/C fixed. Used OEM Acura clutch kit ending in P73-003, which means the ITR clutch and pulley is unique to the type R.
Old Jun 10, 2010 | 05:47 PM
SuperCivic's Avatar
BTW I ended up using the compressor from a JDM OBD1 B16, as it is identical to the ITR compressor. Only thing different is the magnet and the clutch kit.
Old Jun 11, 2010 | 06:36 AM
Jerks's Avatar
damn lol
you answered your own questions
good ****!
austinsamson
Honda CR-V & Element
Apr 23, 2018 08:58 AM
Zebra
Honda Civic (2006 - 2015)
Jan 25, 2018 09:14 PM
johnone
14
May 22, 2014 09:17 PM
immajackuup
Sep 11, 2008 07:16 PM
jabroni95gsr
Dec 9, 2004 04:41 PM
