my 16in rota's don't with with my new brakes. Help me?
Old Sep 13, 2002 | 08:47 AM
TruePlayaz114's Avatar
Default my 16in rota's don't with with my new brakes. Help me?
I recently bought the slipstreams in 16 with falken azenis 215/45/16. The day after i ordered those I ordered the civic 4 piston caliper kit. The kit says that it fits 15in wheels. Well I received everything and mounted up the tires on the rims then i was getting my brakes installed last night then we finish and put on the tire then all it does it hit the caliper. Brian at Fastbrakes told me that 15's fit so shouldn't 16's fit. All they do is hit the caliper. What do i do? My car is on jackstands and i can't go anywhere. Help me?
Old Sep 13, 2002 | 08:53 AM
Brian*'s Avatar
Default Re: my 16in rota's don't with with my new brakes. Help me? (TruePlayaz114)
try a 5mm spacer
Brian
Old Sep 13, 2002 | 08:57 AM
racecarpete's Avatar
Default Re: my 16in rota's don't with with my new brakes. Help me? (Brian*Black99Si)
yep try a spacer, the slipstreams usually require it.
Old Sep 13, 2002 | 09:00 AM
me and my mechanic put spacers i'm not sure what size they were and it still hit the caliper. My mechanic said the only thing i could do is either new rims again which sux or i get my wheel lugs extended and put a bigger spacer. The more spacers i put the less i can put on the lugnuts which is not safe. So if i get a longer wheel lug and put more spacer i can still put on the lug nuts a lot. (if that makes sense)
Old Sep 13, 2002 | 09:02 AM
Brian*'s Avatar
well, for reference, a friend is running the FastBrakes wilwood kit on his hatch, and is running a 5mm space with 15" slipstreams and clears it with out any problems. perhaps the mechanic wasnt using a 5mm spacer
Brian
Old Sep 13, 2002 | 09:03 AM
vtecvoodoo's Avatar
Future Texas Boy
e-mail Brian. He can tell you exactly what to do.
Ryan
Old Sep 13, 2002 | 09:05 AM
Brian*'s Avatar
Default Re: my 16in rota's don't with with my new brakes. Help me? (vtecvoodoo)
and Ryan doesnt mean me
Brian
Old Sep 13, 2002 | 09:06 AM
vtecvoodoo's Avatar
Future Texas Boy
edit lol
[Modified by vtecvoodoo, 6:09 PM 9/13/2002]
Old Sep 13, 2002 | 09:59 AM
Losrocket_'s Avatar
Thats weird. Ive seen the 4 piston kit from Fastbrakes on a car with 16's and they cleared fine, and it didnt have spacers. Im not sure about 15's but they should clear 16's without a problem.
Old Sep 13, 2002 | 10:01 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: my 16in rota's don't with with my new brakes. Help me? (Losrocket'91)
I`m have 16`s and this kit, not even close to contact
Old Sep 13, 2002 | 11:13 AM
my mechanic told me that it could have something to do with the offset since i have a 45 offset. What do you guys think. I'm thinking about going to discount and buying 5 mm wheel spacers and trying it.
Old Sep 13, 2002 | 11:39 AM
does the offset have anything to do with it?
Old Sep 13, 2002 | 11:51 AM
owen_the_soyboy's Avatar
yes that is the deciding force here.... you are hitting the side/face of the caliper, correct?
the offset is your problem
Old Sep 13, 2002 | 11:57 AM
Default Re: my 16in rota's don't with with my new brakes. Help me? (owen_the_soyboy)
so if the offset is the problem then how do i correct it? Yes i am hitting kinda the side face of the caliper. I need the answer as soon as possible my car is on jackstands and i can't go anywhere.
Old Sep 13, 2002 | 01:44 PM
Brian*'s Avatar
the spacers correct the wheel offset. they will move the wheel outwards from the hub
Brian
Old Sep 13, 2002 | 02:27 PM
but yesterday me and my mechanic tryed wheel spacer and it didn't work it still hit. I'm not sure what size they were but we put 2 washers on each lug and it still wasn't enough. Should i put more until it works? Or should i get my lugs extended and then put more spacers?
Old Sep 13, 2002 | 02:39 PM
Jimmy L's Avatar
Don't use washers, use some hubcentric spacers like H&R. Like mr. voodoo said, you should give brian a call, he'll help you.
Old Sep 13, 2002 | 02:44 PM
Default Re: my 16in rota's don't with with my new brakes. Help me? (Jimmy L)
i've been calling like hell but no one answers
i lieft a message
Old Sep 13, 2002 | 04:25 PM
Brian*'s Avatar
duuuuuuuuuuuude, spacers dont = washers. get a real spacer, not some backwoods excuse for one. a hubcentric spacer is what you need
Brian
Old Sep 13, 2002 | 05:07 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Like everyone else said... quality product like H&R or similar hubcentric 5mm spacer.
The SW388s, and I assume the Slipstreams, have spokes that go way into the wheel. For an exact opposite, look at Volk TE37s. You can fit a lot of brake kits that require 16s in 15" Volks.
Old Sep 13, 2002 | 09:32 PM
Default Re: my 16in rota's don't with with my new brakes. Help me? (SkyeC)
so where do i get these spacers at and how much do they run
Old Sep 14, 2002 | 05:04 AM
search online for H&R spacers.. you might need ones as big as 5mm
bassplayer
Suspension & Brakes
Jan 5, 2010 03:49 PM
nightrider93ex
Feb 12, 2009 09:06 AM
shaggyeg6si
Oct 9, 2008 07:47 AM
brandobot89
Sep 13, 2008 09:14 PM
racecarpete
Jul 12, 2002 06:00 PM
