Adding torque?
These are the tools I plan to use, whenever I change my spark plugs. How much torque should I add, to the 13ft lbs requred, for the spark plug swivel tool? I was thinking 15 lbft (+2lbft) would do it, but maybe not.
PS: is that a ball swivel or universal joint type (looks like ball from pic), if ball I would not worry .
Yes, it's a ball. It's just that everyone on these forums is always saying how important it is to not tighten them too much (stripping the threads on the head), or not enough (plug comes loose and flies out). I guess I'm just too picky about things, and want everything by the book. I'm not an experienced tech, so I try to do everything exactly as the manual says.
Again if you can keep it at 90deg with ball type joint i think you can get away . I don't have any universal type joints as i hate them ,flopping around so much .
http://home.jtan.com/~joe/KIAT/kiat_3.htm
I read the link, and it answered my extension question. I'm pretty sure I will be able to keep the angle at 90 degrees, but it is a tight squeeze for the rear bank plugs. Thanks again.
I am sure you have seem wheel torque sockets for air impact that limit torque by there small cross section area of extension shaft .This affect you don't want when using torque wrench .
dohc_profile
Jan 7, 2006 02:07 PM
TimsTeg
Apr 20, 2003 08:55 PM
