!PARTZ! d,b,h,eg, da !PARTZ!
Old Jun 6, 2010 | 05:37 PM
noremorseracing's Avatar
Default !PARTZ! d,b,h,eg, da !PARTZ!
so thruout my honda journey i acquired alot of misc partz.. 4 eg's , 2 ej1's,a Da and a ef later and heres wut i got just chillin in the garage collecting dust , alot of the parts are new.. or slightly used, im not gonna sell garbage, all the parts that arent worth a **** have been sent to the scrapyard..
im down for trades (since this is trader-tech these dayz) ... eg patch panels, skunk 2 intake for h22, h22 fuel rail, rear lca'z or CASH
driver and passanger EG HATCH SEATS, driver side has a tear not 2 bad, 20 for the driver , 30 for the passanger, or 45 bux for both
1.94-01 acura integra B18b1 intake no tb bare $25
2.89-92 odb1 b16a intake has one sensor no tb $50- SOLD
3.90-93 acura integra b18a1 intake automatic $25
4.92-95 honda civic eg tail lights stock no cracks no dings $50- sold
5.odb1 chipped p06 ecu tuned to run like a p72 (gsr)
3500rpm vtec, 2 step launch 4500 rpm, red line 9200rpm, shift light 6800rpm $120 SOLD
6.vtec sub harness for cars with no vtec wire hooked up like a eg or a ef , its just the wire to the vtec and the knock sensor, really easy to install - $50 SOLD
7.egay b- series header no downpipe has o2 sensor $10
9.90-93 integra or 92-95 civic power steering pump new $50
10. 2 iacv (idle air control valve) $25 a piece
11. 2 map sensors $15 a piece
12. 92-95 civic eg mirror driver side needs painted already primer $15
14. power steering bracket for b18 $5
15. charcoal canister for a integra or civic $15
16. 90-93 acura integra throttle body $25
17. 92-01 civic d16 throttle body $25
18. 89-99 civic d15b throttle body $25
19. new gsr cap $10 (mite also still have b16 cap i have to check my boxes of stuff)
20. 90-01 integra b series starter $50 - SOLD
21. b series water pump $25
22.heat shield b series $5
23. d16 ac condensor $20
24. b series ac condensor $20
25. b series ac condensor with some lines hooked up $45- sold
26. B SERIES VTEC SOLENOID - $20
92-95 NEWcivic ball joints - $20 a piece- sold
88-91 ef civic cargo cover - $20 will include a penut butter one and black
h22a stock exhaust manifold (downpipe cut in half got it with swap) will include heat shield $15
used 50mm main crank with pistons and rods from a h22a . perfect working order.motor had 78k when my buddy got it and tore it apart...only reason they were took out was for a n/a build...150 cash money...
NISSAN
98 nissan altima stock radio- $15
98 nissan altima passanger side turn signal oem- $15
Old Jun 8, 2010 | 05:36 PM
Default Re: !PARTZ! d,b,h,eg, da !PARTZ!
ttt
Old Jun 8, 2010 | 07:10 PM
eg_21's Avatar
ttt
Old Jun 11, 2010 | 06:56 PM
bump
Old Jun 12, 2010 | 12:03 PM
partz..
Old Jun 14, 2010 | 01:28 PM
ttt
carlosd68
Northern California (Sales)
Jul 17, 2014 06:17 PM
noremorseracing
Jul 27, 2010 01:01 PM
noremorseracing
Jun 3, 2010 05:17 PM
noremorseracing
Apr 20, 2010 01:15 PM
noremorseracing
Mar 7, 2010 07:48 AM
