1991 Honda Accord DX (2door 4 cyl) Problem
Old Jun 6, 2010 | 03:55 PM
vynum's Avatar
Icon6 1991 Honda Accord DX (2door 4 cyl) Problem
ENGINE DIES WHEN GIVEN THE GAS
IDLES FINE @ IDLE OR REVVED UP TO 1,500 RPM
ENGINE IDLES FINE AT 2,000 RPM'S
ENGINE DIES IF GIVEN A QUICK PUNCH ABOVE 2,000 RPMs
CANNOT DRIVE, ENGINE WILL DIE
note: The humidity today has been at 82%.
Hi guys,
I got a problem here with my wife's car and was wondering if someone could help me find the problem? I will try and explain in detail what is going on. It's pretty simple as to what's happening.
3 months ago, I noticed when coming to a red light or a stop sign, the car would idle perfectly then dip a bit. It would dip in RPM's like it was drowning then go back up and be ok. Well, I payed no further attention cause the car still ran fine. Then yesterday my wife headed off to work and came back to the house really quick. I asked here what's wrong? She said, " The car keeps dieing on me".
I checked it out and this is whats happening:
The car will sit and idle ok. well, it still has that little dip in RPM's but doesn't die at that point. I rev the car up to about 1,500 RPM's and leave it there and nothing happens. But, when I bring it back to idle, right at about 800 RPM's and REV it quicly back up higher than 2,000 RPM's The yellow engine light comes on and the car dies. It dies like it just simply ran out of gas. But it has gas. It will crank right back up with no problem.
If I put it in drive and go real slow its ok, but when I give it the gas it accelerates then yellow engine light comes on again the engine quickly dies. Pushing on the gas does not revive the engine from cutting off at this point.
But, if I crank it back up and let it sit and idle, it idles fine. So, my question is this. What could be causing this? I'm thinking either, fuel pump, fuel filter, oxygen sensor or some type of sensor? I could be wrong though.
Oh, I did let the car rest for 2 hours with battery + and - disconnected. Cranked it back up and I'm getting 6 beep codes. They are six beeps only, no long tones at all.
What does the six beeps mean? The beeps are coming from under the passenger side seat
Your help would be appreciated.
The car has about 148,000 miles and has been well taken care of. The last repairs we had done was replacing both CVC joints at about $350 bucks. I also had to take out the MAIN RELAY and re-sawder the contact points on the computer circuit board because it was having starting problems in hot or humid weather. Car has been running fine for about 2 months after these repairs until now, the engine light comes on and the engine dies.
note: For the MAIN RELAY repair I did, I followed the instructions found here, they were great!:
http://techautorepairs.com/mainrelaydefine.html
Old Jun 6, 2010 | 06:23 PM
phootbag's Avatar
Default Re: 1991 Honda Accord DX (2door 4 cyl) Problem
Retrieve the DTC from the ECU memory. The ECU doesn't "beep" the DTC. That could be your seatbelt reminder.
Old Jun 6, 2010 | 06:55 PM
vynum's Avatar
Thanks for responding phootbag,
Yes the beeps were because my seat belts were unplugged. But, from my description of the problem what do you think it could be?
I removed the kick panel on the passenger side and located two connecting wires attached to the wall. one is a brown 2 pin. The other is larger. Would the brown 2 pin be my Service Check Connector" , the one I need to short with a paper clip to retrieve the DTC from the ECU memory?
note: I found this diagram for Diagnostic Trouble Codes anyone else who needs it:
http://techautorepairs.com/dtc.html
Old Jun 6, 2010 | 07:05 PM
phootbag's Avatar
Jump the Service Connector and turn the key on ( not start ) and watch the Check Engine Light. Check the definition of the code. I wouldn't start trying to track anything down until you retrieve the code.
Old Jun 6, 2010 | 07:56 PM
vynum's Avatar
ok, will do.
thanks
treym187
Feb 17, 2011 11:10 AM
Bruce Lee
Nov 5, 2005 05:49 PM
psyonicdeath
Jul 1, 2005 07:25 PM
