Transmission & Drivetrain Gearboxes, Differentials, Clutches
Tranny fluid leakage
Old Jun 6, 2010 | 12:41 PM
litoekneeil's Avatar
Default Tranny fluid leakage
Hey everyone
Recently I blew my em1 tranny. The differential broke and cracked the bell housing. So I swapped the internals into a LS tranny and threw on a GSR Diff. I sealed it with hondabond and changed all 3 seals. Well my problem is, I am leaking tranny fluid. Im having a really big headache over this. Im pretty sure I am leaking from the driverside of the tranny. Did I not install the seal correctly? Is there a correct way? When I put the seal in, I put it sitting flushing with the housing.
SOMEONE HELP MEE!!! thank you
Old Jun 6, 2010 | 02:24 PM
Honda Bull's Avatar
Default Re: Tranny fluid leakage
You can only be leaking from axle seals, fill and drain plugs, two shift ball bolts, shift rod seal, input shaft seal, between the casings, or the two plugs in the top of the trans housing. There's nothing for anyone here to say. You just have pull the trans and fix what's leaking.
BTW, did you check the clearances for the diff and mainshaft? And did you make sure no debris or shavings made their way into either shaft's oiling ports? The leak could be the least of your worries if you didn't bother with these two procedures.
Old Jun 6, 2010 | 03:56 PM
When I put everything together, I cleaned everything. I mean everything. I cleaned it so clean that you could eat off it. From the looks of my tranny, it looks like im leaking from the driver side axle seals. Is there a certain way to put it in?
Old Jun 6, 2010 | 06:11 PM
sh!ft's Avatar
Who the fack changed my title?!
you forgot a bolt..... the reverse shaft bolt lol
Old Jun 7, 2010 | 06:39 PM
could my halfshaft being slightly crooked be the cause of my tranny oil leak?
Old Jun 8, 2010 | 08:53 AM
Honda Bull's Avatar
Yes. lol But you really have some issues if you leak out of that.
jdmstyleEJ6
12
Apr 2, 2010 08:07 PM
Inextricabledrvr
Nov 26, 2009 11:03 AM
Themouse
Nov 22, 2006 05:10 PM
civicboisi
Nov 15, 2004 07:56 AM
