What could be frying my icm, ecu?
Old Jun 6, 2010 | 10:51 AM
db1love's Avatar
Icon6 What could be frying my icm, ecu?
car is '97 ek with obd1 jdm gsr
The car shut of while driving and would crank but not start, 15 mins or so later it would fire up and run for a little while and then shut off again. I replaced the icm with nology profire ignition module and coil, car ran fine for 8 months or so. Last night same problem came back. Engine was missfiring, tach was jumping all over the place and then the engine shut off. Cranked and no start, then started and back fired and then shut off. 15 mins later the car fired right up and idled no problem, checked for codes and pulled a code 15. I let the car sit over night and this morniing it fired up and I drove it 10 miles home with no problem.
Help please before I just use a stick of tnt to fix the situation.
Old Jun 6, 2010 | 11:06 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: What could be frying my icm, ecu?
use a factory ICM, the rest are junk
Old Jun 6, 2010 | 12:44 PM
rxbahamut's Avatar
Other than what Honda Parts hero said, you might have a wire wiggling some where and ground itself shorting out the ECM, it would be rare it would last that long and happen again but anything is possible.
Old Jun 8, 2010 | 04:02 AM
db1love's Avatar
I replaced two ICM's before I went to the Nology set up. Something ihas to be causing them to fail.
triton318
Sep 28, 2010 11:48 AM
Ryan.
Apr 29, 2008 11:48 AM
slammedvtec
Apr 17, 2008 02:17 PM
rdssk8rcs1
Oct 29, 2006 01:06 PM
FOrSfEd
Jul 18, 2005 09:41 AM
