Suspension & Brakes Theory, alignment, spring rates....
Best setup for 17x7 +40mm?
Old Jun 6, 2010 | 10:35 AM
Keenor's Avatar
Default Best setup for 17x7 +40mm?
I have a 2000 Civic hatch, offset is +40 and the rims are 17x7..
I want to lower the entire thing by about 2 inches, I don't want any rubbing to occur, so with leaving the camber alone, would it be negative enough to clear the fenders? Do I have to buy a camber kit to make it even MORE negative?
Also, I'm looking for the cheapest setup possible, roads are good, not looking for amazing ride quality.. Coilovers are not an option due to price.
Could I just swap the springs for now, and down the road replace the shocks? Best bang for my buck, what is it?
Thanks for any help!
Old Jun 6, 2010 | 11:17 AM
98civdx's Avatar
Master Detailer
Default Re: Best setup for 17x7 +40mm?
You could just swap the springs but you will want shocks to go with.
Look at eibach, tein, h&r, progress
but those rims are pretty freaking big wether you will rub or not i dont know.
Old Jun 6, 2010 | 07:30 PM
Da-Risin-Smoke's Avatar
You want low but you don't want to roll your fenders?
Old Jun 7, 2010 | 05:12 AM
kyden's Avatar
you'll have no problem with that offset.
Old Jun 7, 2010 | 11:22 AM
Keenor's Avatar
Alright, well currently the wheels are a few mm wider than the fenders, so with 0 camber lowered 2 inches it would be very bad..
So dropping it 2 inches and leaving the camber how it sits would be fine? Also, leaving the negative camber is okay, but I need an alignment done from what I understand? To avoid uneven tire wear?
Thanks again.
Old Jun 7, 2010 | 11:40 AM
kyden's Avatar
correct. it will not rub if you do no camber corrections.
kingbrian
Honda Civic (2001 - 2005)
Oct 2, 2008 03:41 PM
haophat
Mar 2, 2004 07:35 PM
HondaD15BtoB16A
May 4, 2003 03:43 PM
osbornsm
Sep 1, 2002 08:41 AM
