Built nasty turbo motor, make huge power!!!!!!!
Old Jun 6, 2010 | 09:33 AM
slick1851's Avatar
Default Built nasty turbo motor, make huge power!!!!!!!
Engine
dart block 84.50mm bore
LS crankshaft*
JE pistons 9.3:1 compression,upgraded wrist pins and piston rings
Eagle H-beam rods
Moroso 5.5 quart deep sump oil pan with pickup
Type R oil pump
Cometic extreme duty head gasket*
ARP head studs
Golden Eagle head dowels
B16 head
3angle valve job
Stainless Crower 1mm oversized intake valves, .5mm oversized exhaust valves
Crower stage 2 turbo cams
Crower duel vavle springs with titanium retainers
Crower adjustable cam gears
TODA timing belt
CTR crank pulley
King Motorsports extended intake manifold studs
Stainless ARP exhaust manifold studs
Edelbrock Victor X intake manifold with Edelbrock throttlebody
stock fuel rail
B&M fuel pressure regulator
RC 750cc saturated fuel injectors
Turbo setup has been ssssoooollllldddd!
Precision SC60 turbo
Peak boost ramhorn turbo manifold
Tial 38mm wastegate*
Tial B.O.V.
Hondata S300.
Old Jun 6, 2010 | 09:35 AM
slick1851's Avatar
Default Re: Built nasty turbo motor, make huge power!!!!!!!
Asking 1700 for the built head and 3500 for the short block obo! Or buy both for 4,600 I do not want to remove the head from the block. This is a badass setup, for big power guys! 630 347 4107
Old Jun 6, 2010 | 09:46 AM
slick1851's Avatar
Zero miles still sitting in a engine bag
Old Jun 6, 2010 | 12:13 PM
hrs-parker's Avatar
sick build...glws
Old Jun 6, 2010 | 08:58 PM
3doormafia's Avatar
bump for a great set up
Old Jun 7, 2010 | 03:23 AM
slick1851's Avatar
Tracks are open!
Old Jun 8, 2010 | 06:47 AM
slick1851's Avatar
Bump obo
Old Jun 8, 2010 | 08:22 AM
Honda1949's Avatar
Hi..interested in the longblock...Never run?, who did the work and final assembly...Thanks ,Bob
Old Jun 8, 2010 | 12:19 PM
slick1851's Avatar
Never run zero miles, brand new....dougless machine in WI. I really just don't have the time for a project like this.
Old Jun 8, 2010 | 12:20 PM
slick1851's Avatar
I'll bring the motor to anyones machine shop to have it looked over. Nothing to hide make a offer.
slick1851
Jul 24, 2010 10:30 AM
slick1851
Jul 8, 2010 08:27 AM
slick1851
Jul 1, 2010 09:19 PM
slick1851
May 29, 2010 10:48 AM
wyte_rice
Apr 4, 2010 02:37 PM
