vapor lock
Old Jun 5, 2010 | 08:28 PM
Eks_86's Avatar
Default vapor lock
so today i tried starting my car it wouldnt crank over i think its vapor lock.how do i fix it? help.has spark theres fuel idk
Old Jun 6, 2010 | 04:56 AM
~sp33~'s Avatar
EFB055
Default Re: vapor lock
I think you're thinking of hydro lock, not vapor lock.
If it's not cranking over, the most likely cause is going to be a dead battery, or a loose connection at the starter motor. Check those.
If they all seem in check, try turning the engine over by hand if you're worried that it has seized, which is unlikely (you'd have known if it had seized).
Old Jun 6, 2010 | 05:21 AM
Foowee's Avatar
If you're getting fuel at the rail/squirts, it's not vapor lock...
http://en.wikipedia.org/wiki/Vapor_lock
Actually, I don't think it's possible to vapor lock a fuel injected vehicle...
If it wouldn't crank how do you know you have spark?
Old Jun 6, 2010 | 06:16 AM
TheCheeseWedge's Avatar
pull your plugs check to see if your cylinders are filled with fuel, if so get a hose and a wet-dry vac and suck out the fuel
wipe down spark plugs take lighter to sparkplugs lightly burn off and fuel
put everything back together
then recheck all of your grounds
report back
Old Jun 6, 2010 | 06:33 AM
~sp33~'s Avatar
EFB055
Or just leave the plugs out, the fuel will evaporate.
Old Jun 6, 2010 | 06:39 AM
yeah that will work too im just really impatient lol
WifesVTEC
Jan 31, 2011 04:46 PM
Jabinya
Jul 13, 2007 05:49 AM
czer47
Jun 28, 2007 10:49 PM
skUnK2jdm
16
Feb 10, 2007 02:43 PM
pbizzlegsr
Aug 27, 2004 08:55 AM
