LS blocks F/S
Old Jun 5, 2010 | 07:45 PM
ELIJAH EG-2's Avatar
Default LS blocks F/S
LS blocks for sale....
Name ELI
Item and description As listed below
Price As listed below
Location La Vergne
Contact information pm
First block is bare.....comes with the crank and caps along with the piston and rods that came out of it. In good shape perfect for building a boost setup from scratch or LS-V.
$100.00
Second block in still in the car ( will need main and rod bearings ) when changing out the pan due to the last person that installed a oil pan incorrectly with out replacing the oil pan gasket. I was replacing the oil pan with a new pan and new gasket from Honda when inspecting the oil pan that came off the motor there was some metal flake so that ment that there is going to be a bearing that will go soon. not sure witch one it is??? motor runs great no issue doesnt burn oil or coolant!!! You can hear it run before I pull it.....
$300.00
__________________
Old Jun 6, 2010 | 12:38 PM
Default Re: LS blocks F/S
bump new pics added.....
Old Jun 7, 2010 | 05:39 AM
delsol-slow's Avatar
bump for my boy!!!!
Kronn 98SH
Mar 25, 2009 12:40 PM
tonygtec
Nov 10, 2008 06:53 AM
brian_98EK
Jul 21, 2008 10:32 AM
DXK Eg
Feb 24, 2005 10:28 AM
atos_152
Jul 30, 2002 11:47 AM
