Oh hey 4th gear, where'd you go?
Old Jun 5, 2010 | 11:34 AM
Nate13's Avatar
Default Oh hey 4th gear, where'd you go?
So, driving home from Hershey Park last night, my EP decided it didn't want to go into 4th gear anymore. Car runs fine, shifts into every other gear just fine, no 3rd gear grinds even. It just will not physically engage 4th, cant even get the shifter to move into it. I didn't hear and noises or hit anything so I have no idea where this is coming from. The shift linkage isn't blocked by anything on the outside of the transmission.
Would changing the trans fluid help? I just changed it (with Honda MTF) about 7k miles ago and everything was fine.
Any help is greatly appreciated!
Old Jun 5, 2010 | 12:50 PM
turboteg2nv's Avatar
Default Re: Oh hey 4th gear, where'd you go?
Clutch might be on it's way out..
but yeah check your tranny fluid level to start diagnosing the problem. It should be level with the fill bolt (I'm sure you knew this already).
Old Jun 5, 2010 | 02:27 PM
Nate13's Avatar
could be the clutch..i'm at about 125k on my 2002 and still on the original from the best of my knowledge. I'm the second owner, bought it with about 100k on it almost a year and a half ago so i have no record of it was changed or not.
Old Jun 5, 2010 | 09:34 PM
cloumep3's Avatar
sounds like a clutch..., but might be synchro issue..., check fluid first like turboteg2nv suggested.
Old Jun 6, 2010 | 06:19 AM
bigdaddy496's Avatar
i havent been to hershey park since 1983
Old Jun 6, 2010 | 07:01 AM
simonEp3's Avatar
I had a similar problem on my way back from Nashville. My car kicked itself out of 5th gear and then never wanted to go back in...I was seriously only doing 70 in the interstate and I wasn't driving crazy...bad synchcros FTL...
Old Jun 6, 2010 | 08:51 AM
Nate13's Avatar
haha I was born 5 years after your last trip to Hershey Park BigDaddy
I hope it's not the synchro, It didn't kick out of gear, I just went to shift into 4th leaving the parking lot, and it wouldn't go in.
Old Jun 6, 2010 | 11:40 AM
i miss the east coast
Old Jun 6, 2010 | 07:43 PM
cloumep3's Avatar
Originally Posted by Nate13
... I hope it's not the synchro, It didn't kick out of gear, I just went to shift into 4th leaving the parking lot, and it wouldn't go in.
I had similar issue with my 3rd gear..., at first it needed little force to go into 3rd, then wouldn't let me go in at all, and finally went in and wouldn't let me disengage it...
Opened up the tranny; f*ck*d up clutch, badly worn throwout bearing, no good synchro, flywheel... you get the idea...
Old Jun 7, 2010 | 06:33 AM
Nate13's Avatar
Originally Posted by cloumep3
you get the idea...
yea, [expletive deleted]
Old Jun 8, 2010 | 01:14 PM
Nate13's Avatar
Just topped off the trans fluid, might have been a tad low, took less than 1/5 quart to make it run out of the plug hole. Still can't get 4th to work...
Old Jun 8, 2010 | 04:40 PM
kobeballer96's Avatar
sounds like a clutch/throw bearing issues it happened to me at 95k miles
Old Jun 8, 2010 | 08:03 PM
dont know if that would be it, if the car can go into any other gear but 4th, i would think theres something else at play here.
Old Jun 11, 2010 | 07:33 AM
Nate13's Avatar
going to trans shop on Tuesday
Old Jun 11, 2010 | 07:40 AM
Honda Bull's Avatar
Local guy! How was the park btw? lol
I can't see it being a clutch issue if it's only one gear. The clutch will normally affect every gear. Given that it simply won't pull into the gear, sounds to me that your 3rd gear synchro sleeve's teeth mushroomed over and won't let it slide down the synchro hub. Usually this happens from the sleeve getting beat up on the dogteeth on the gear itself (i.e. grinding). Odd that you mentioned 3rd doesn't grind at all but you're experiencing this.
Old Jun 16, 2010 | 02:05 PM
Nate13's Avatar
Icon3 Re: Oh hey 4th gear, where'd you go?
HP was great, got a friend that works there so free admission
IF anyone has a 5spd trans in SE PA, DE, South Jersey, North Maryland PM me asap!
Old Jun 16, 2010 | 08:49 PM
will look around for ya
Old Jun 18, 2010 | 07:14 AM
Nate13's Avatar
found 1:
05, 5 spd, 32k miles, $600
good deal?
Old Jun 19, 2010 | 05:14 PM
Nate13's Avatar
Are there ANY differences between the 05 and 02 trans'? (I know they fixed the third gear grind issue internally) I just want to make sure my 02 to 05 trans swap will but a simple pulling of the old and slappin on the new one
Old Jun 19, 2010 | 05:17 PM
speedooo's Avatar
If it was the clutch, it would be hard to get into every gear. Sounds like it's an internal issue specific to 4th gear.
Old Jul 3, 2010 | 12:13 PM
BigJ_RSXPA's Avatar
Who needs 4th gear anyways? Just shift from 3rd to 5th!
Old Jul 8, 2010 | 07:15 AM
Nate13's Avatar
thats what ive been doing to get to work, so im not really in a huge rush to fix it.
BIGJ you in KOP? im from right below Kennett Sq., PA
Old Jul 8, 2010 | 07:46 AM
BlitzSix's Avatar
AFAIK you need a VSS converter to get the speedometer working if you run an 04-05 tranny on an 02-03.
Old Jul 9, 2010 | 06:05 AM
Nate13's Avatar
Thanks that a great help. You know where I can get one?
Old Jul 9, 2010 | 08:19 AM
cloumep3's Avatar
Hybrid racing has one...
http://www.hybrid-racing.com/store/h...veter-box.html
sportinjected
Jul 9, 2008 08:21 PM
gsteggy
Nov 28, 2007 05:10 PM
slayersluck
Jan 13, 2007 11:36 PM
rizq777
Sep 25, 2004 07:57 AM
tyflip2
10
Nov 14, 2003 11:49 PM
