Wiseco 9:1 b16 pistons in b18c
Old Jun 4, 2010 | 11:25 PM
ghostskinner's Avatar
Default Wiseco 9:1 b16 pistons in b18c
Wiseco 9:1 b16 pistons in b18c what is the compression ratio going to be
Old Jun 5, 2010 | 11:06 AM
king06's Avatar
Default Re: Wiseco 9:1 b16 pistons in b18c
Probably around 9.8, just a guess.
Old Jun 6, 2010 | 08:04 AM
TheShodan's Avatar
Moderator
compare the part number piston that you have to the catalog sheet that Wiseco uses. they typically use the same part number, in the columns next to the description it shows what the compression ratio would be. Compare the B16 and B18C and you have your answer. so for example, if you have K542M815 for b16 from the catalog, it gives you 8.8-9.0:1 CR. Find that part number above in the integra 94-01 portion, and your CR for that same part number is 9.7:1-10.2:1.
Here's the catalog for your reference
http://www.wiseco.com/PDFs/Catalogs/SC07/AcuraHonda.pdf
Old Jul 2, 2011 | 03:12 PM
Bu7head's Avatar
i was going to do b16 in the b18b ls block but i want to boost it wouls i just use b18 pistons with low cr or same b16 low cr??
Old Jul 2, 2011 | 07:59 PM
alperx's Avatar
9.9 : 1
calculated via http://www.zealautowerks.com/bseries.html
Old Jul 3, 2011 | 05:51 AM
00Red_SiR's Avatar
All Motor Mentor
When you calculate the added stroke and slightly smaller combustion chambers of the B18c1 head, you will go from a 9:1 rating in a b16a, up to 10.2-10.5:1.
sohcvtec706
Mar 4, 2007 02:01 PM
Bense
26
Aug 27, 2004 11:12 AM
S2KP
Oct 23, 2003 09:05 PM
92JDMSiR
Apr 18, 2002 02:10 PM
