Will Swap Pass Smog?
Old Jun 4, 2010 | 10:28 AM
phoxking's Avatar
Default Will Swap Pass Smog?
will a 96 civic with b18c1 swap from a 98 pass smog? i got all the wiring redone and the gsr exhaust sensor on the cat* only thing is one plug is in and the other isnt because their is no where else to plug..
i'm planning to bar it, but i want to see if i can do smog so i can get my tags already.
Old Jun 4, 2010 | 11:14 AM
phoxking's Avatar
Default Re: Will Swap Pass Smog?
anyone? bump.
Old Jun 4, 2010 | 11:38 AM
canadaek's Avatar
if everything is installed correctly and working passing smog should be ok as its a newer motor then the car not sure about bar (i'm in canada) but i don't see why it wouldn't pass but what do you mean only one plug of exhaust sensor ??? you mean the oxygen sensor ?? what model is your civic if its a dx or cx i think you have to add or lenthen the wire's for the rear sensors as on the d16y7 the cat is in the manifold not under the car like an EX hope some of this helps.
Old Jun 4, 2010 | 01:34 PM
phoxking's Avatar
thanks that was helpful yeah its a cx model and the gsr motor only has one plug which im confused about but i have 2 wires that are on the sensor
Old Jun 4, 2010 | 03:14 PM
EL Vap133's Avatar
You have to get it BAR'd before the smog people can smog you car.
speedaholic92
226
Oct 21, 2011 10:50 AM
BRIANxJDM
Jul 21, 2009 05:00 PM
boots420
37
May 18, 2007 03:35 PM
delslowhonda
May 2, 2006 10:52 PM
NewBorn_EG
May 30, 2004 02:59 PM
