passing smog with aftermarket cams
Old Jun 4, 2010 | 10:27 AM
boxeocampeon's Avatar
Default passing smog with aftermarket cams
close
Old Jun 4, 2010 | 11:50 AM
SD_Lurker's Avatar
HT White Ops
Default Re: passing smog with aftermarket cams
That's a lot more than cams.. At this point I think its going to depend on your tune.. Obviously being turbo the tune will play a part in whether or not the car will pas..
Old Jun 4, 2010 | 11:54 AM
TheShodan's Avatar
Moderator
that's pretty much it. No one component will determine pass or fail like that on a turbo application
Old Jun 4, 2010 | 05:20 PM
TheShodan's Avatar
Moderator
All you can do is try. There is no definate method for doing this except going back to stock injectors, disconnect intercooler pipe and stock ECU.
Old Jun 4, 2010 | 08:39 PM
DC4KiD's Avatar
Your car will fail as soon as the OBD2 scanner is plugged in (won't detect ECU; monitors status, readiness status, etc).
raverx3m
Jul 19, 2015 03:32 PM
BKKloppenborg
May 28, 2007 07:28 PM
is3oo
Mar 2, 2005 01:05 PM
95EXcivicsleeper
Sep 15, 2004 03:37 PM
STEALTHMODECOUPE
Sep 24, 2002 09:00 PM
