ZC motor....just throw it in...or rebuild it???
Old Sep 13, 2002 | 06:06 AM
Kasper.'s Avatar
Default ZC motor....just throw it in...or rebuild it???
As topic reads.....many of you might know I just did a a6 headswap..and mpfi convertion....runs okay besides the fact my d15b2 block is just really trying to quit on me and I burn alot more oil then I used to.
I have to go to school soon actually I leave tomorrow(car is getting put on a flatbed lucky me)
and I have to drive about 15-20 min from my apartment....now I used to street race but ive really kinda quit on that....Im getting into auto-xing....and just enjoying my car....I know im going to buy a ZC for money's sake.....and becuase Ive already got everything for it....just need to do the swap...
but for 500 bucks.....is it worth it to YOU..to put new rings/bearings/seals/headgasket/timing belt/water pump...in..???? How much is all that? Just give me an estimate...
Or for 500 bucks should I just throw it in?? Ive never really heard of ZC's being wonderful from japan..most are actually pretty old and tired.....
I will be retaining my I/H/E and such......I will say when i do the swap...Ill throw in a ACT clutch...my friend has one in his civic....and although I just got a new oem clutch like 2 months ago..I know it wont last through auto-xing.....
Old Sep 13, 2002 | 06:13 AM
Kasper.'s Avatar
Default Re: ZC motor....just throw it in...or rebuild it??? (Kasper 1)
BTW Im also thinking about a d16z6 or y8......but I kinda want DOHC...and I havent really seen any d16z6's around or anything Ive only called the junk yard about b18s and those run for about 700...in perfect shape for everything...If I could pick up a d16z6 for 300-500...Id def. take that....
Old Sep 13, 2002 | 06:14 AM
USDM 4G VTEC's Avatar
REBUILD IT!!!!
u will thank me later......
i rebuilded my Z6 before swaping.... was good bc my #2 had 125 psi....... u never know when u going to loose power...... anyways its better to have an engine running better than just slap it in and then braking apart.... an engine rebuild can run from 300-600 dependign what u cange, and who does it...
Old Sep 13, 2002 | 06:28 AM
crxgurlllll's Avatar
slap that zc in....youll be disappointed by the power eventually and want to go b series
Old Sep 13, 2002 | 06:55 AM
Wiz's Avatar
Wiz
I'd go for the rebuild, if you do the work yourself you should have some money left over
I have a zc. its reassuring knowing the t-belt waterpump etc was replaced
Old Sep 13, 2002 | 07:01 AM
Malgerus's Avatar
You know, I wouldn't even bother with the ZC. I would just look for a good sohc VTEC, be it D16Z6 or D16Y8. I loved my D16Y8; it was quick! I surprised many, many people with how fast it ran! With just I/E I was running consistent 15.3's, with one 15.2. I also lucked out, because it came with an AEM cam gear (never touched it), and about 210-215 psi per cylinder, across the board. I may actually be selling this engine if I get my car back for scrap.. But seriously, I see a few ZC's that run pretty darn hard, but then I see dogs that run 15.7-15.9's with bolt ons, which IMO is slow...
If you get a Sohc VTEC make sure it comes with a full warranty, and they tell you how much compression it has. Also wire it up correctly with OBD-I, it DOES make a big difference, especially in VTEC.
There was a guy at my local track with a D16Y8 wired off of the stock computer, and he was pulling 16.1's!!
aaroneezee
Mar 28, 2008 10:33 AM
roadhead
15
Mar 22, 2006 06:57 PM
efracer
Mar 17, 2003 08:50 AM
AMChev
May 4, 2002 07:32 PM
AMChev
Feb 8, 2002 08:01 PM
