Clutch alignment tool ?
Old Sep 13, 2002 | 05:54 AM
JPP's Avatar
JPP
Default Clutch alignment tool ?
Can someone confirm to me that the clutch alignment tool is basically a straight rod having the same diameter as the clutch friction disc bore (I will measure tonight). Or is there something more to it?
Thanks
[Modified by JPP, 9:54 AM 9/13/2002]
Old Sep 13, 2002 | 06:04 AM
tonyxcom's Avatar
Default Re: Clutch alignment tool ? (JPP)
The very end is also sized to fit snuggly into the pilot bearing in your flywheel.
It makes life a little easier, but it can be done without it.
I got a universal clutch tool at Pepboys and it was pretty worthless. I ended up eyeballing it and was able to get the tranny on in two tries.
Old Sep 13, 2002 | 06:12 AM
JPP's Avatar
JPP
Default Re: Clutch alignment tool ? (tonyxcom)
Thanks
I will see if I can get the end of the rod machined to the proper dimension at work
lolv8s
K Series
Aug 23, 2015 12:50 PM
MiNeSEK
19
May 11, 2013 12:05 AM
hastingsr
Aug 23, 2008 10:08 AM
ericlee303
Sep 8, 2007 11:34 AM
fastlude69
Jul 14, 2004 07:12 PM
