NY F.S/F.T Vw Corrado built vr6!!!
Hi like the topic says i have a 1992 Slc vr6 for sale . Motor and trans have about 5k on it. Body 136k everything works HAVE ALL PAPER WORK!!
would like to trade for a hatch of some sort and maybe some cash
will get pics up asap
Just replaced oil and filter and spark plugs
4/17/10- autopower rollcage
:engine specs:
rod bearings
main bearings
oil pan
intake and exhaust valves
vavle guides
crankshaft sensor
waterpump
all new gaskets throughout motor
injector seals
shift linkage
stock rods
bored out to 2.9l
je pistons and file fit rings
3 angle valve job
263 cams
TT valvetrain
HD valve springs
mk4 headgasket
02 sensor
g12 coolent
crackpipe
new oil filter housing
new water pump
new temp sensor
new down pipe gasket
new down pipe to manifold gasket
new exhaust manifold gasket
new valve cover gasket
new intake manifold gasket
new mk4 head gasket
new low temp thermostat
new thermostat housing
new fuel pump
new fuel filter
new front crank seal
new rear crank seal
new plugs 4/10/10
new chain
new chain tensioer
6000k HIDS
etc etc etc
:Trans:
Cleaned trans inside and out looked good new trans fluid shifts great
10LB flywheel
diesel geek short throw
Sachs Clutch Kit
etc etc.....
Body has no rust has Patec hole shot coil overs car is obd1 distributor interior is grey and pretty nice trans shifts nice and smooth car has stock bbs wheels with good tires also have original window sticker and papers no drips or leaks of any sort car does not burn a drop of oil
Needs Core Support and right side fender
Color is a brownish Metallic
please email me or call me at 845 519 0773
:engine specs:
rod bearings
main bearings
oil pan
vavle guides
crankshaft sensor
waterpump
injector seals
shift linkage
stock rods
bored out to 2.9l
3 angle valve job
263 cams
TT valvetrain
HD valve springs
mk4 headgasket
02 sensor
g12 coolent
crackpipe
new water pump
new temp sensor
new mk4 head gasket
new fuel pump
new fuel filter
new rear crank seal
new plugs 4/10/10
new chain
new chain tensioer
6000k HIDS
etc etc etc
:Trans:
10LB flywheel
Sachs Clutch Kit
etc etc.....
1990 CB7
Feb 27, 2017 11:40 AM
Maui Built
Northern California (Sales)
11
May 28, 2011 11:40 PM
