vtec bog
Old Jun 3, 2010 | 06:49 PM
jdmgeezer's Avatar
Default vtec bog
i have a b20 vtec with spec3 cams vtec engages but bogs alot does it matter if i have a stock exhaust with a test pipe should it be doing that. what else could be the problem or is the injectors are to small its stock.
Old Jun 3, 2010 | 08:20 PM
killerpenguin21's Avatar
Default Re: vtec bog
is it tuned?
Old Jun 3, 2010 | 09:32 PM
GhostAccord's Avatar
Why did you start a new thread, you already have one started on this very same topic.
Originally Posted by jdmgeezer
i have a built b20 vtec with buddy club spec 3 cams tried to hit vtec yesterday and when i try to engage vtec it seems to sputter and make no power, do i need to get it tuned or running stock injector is causing the problem or the cams the problem, i check the oil level and its fine wiring, pressure everything anybody can help that would be cool
Originally Posted by killerpenguin21
is it tuned?
no its not tuned yet but shouldnt it still be able to engage
I'm guessing that it has something to do with the tune, or lack there of.
Old Jun 4, 2010 | 06:50 AM
i hate ht these days.
Old Jun 4, 2010 | 06:56 AM
LSvtecRSA's Avatar
have you dialled in the cams?
i'd suggest putting it on a dyno and checking the air/fuel ratio first
the_asteroid
May 22, 2008 09:52 PM
ivicr
Jan 10, 2007 01:48 PM
SD1222
Nov 13, 2005 01:21 PM
bpowa
35
Oct 18, 2004 09:43 PM
dpine
11
Nov 3, 2003 10:20 AM
