My del sol transtop project
Building it from the frame up.
Starting off with nothing:
Sand
Weld
Grind
Prime/Seal
Order Parts:
Powdercoat Parts
Order More parts
Work on motor
Rebuild stuff
Oh yeah, I need 6 wheels because...
Lots of work to finish up my trailer, but it'll get there
Shaved the ground and bottom lip down
More engine work
Tranny: Put the 5th gear in and LSD, New clutch is in also
Type R LSD
Turbo mani:
Transtop gears broke again
Rebuilt the transtop tilter
works again
I changed my mind about closing up this hole so it was opened back up
brought the car home for some more body work/primer
Finished up the paintbooth
More turbo parts
even more turbo parts
got the car back to the shop (in the paintbooth)
30 hours straight priming/sanding/bondo/sanding/bondo/sanding
layed down some paint
all the previous work on the engine bay was re-done. (wasnt good enough so I started over)
I didnt really like the Milano red so I repainted it (the 3rd time this week) to "True Red"
Why does nobody keep these rubber linings?
=-0
Took me 30min to put the subframe back on by myself
10min to install the hood dampers (one side was being a bitch to latch on)
Worked on the wire tuck
Heres where it goes through the firewall
zoomed out a bit:
reinstalled these tab thingies for the side skirts
side skirt is on
a little wire-loom makes it all pretty
more stuff installed
test fitted a few turbos, still not sure how im gonna make one fit
tried another "AC Compatible" turbo manifold
Alot more wiring
New overflow tank
Mocking up the turbo pipes
-Axles are installed
-Fluids filled
-Side Skirts installed
-Mudflaps installed
-Electrical (light) issue fixed
-Exhaust installed
-Fenders/Bumper Installed
-Hood/Doors/Fenders Aligned
-Brake rotors surfaced
-Clutch Bled
-Brakes Bled
-Hood & dampers installed
-Battery Charged
prolly more, but here are pics:
Still lots to do
A little flake
I let the pro do the welding on this part
Perfect Fit!
I have been looking for del sol seats so I could get the rails from them forever, finially I got some (Donation from PI Auto in Austin)
I chopped them up
Installed them and measured the width
Cut a cross bar (Home depot steel) and measured/drilled the bolt pattern for the seats
Welded them and spraypainted them black
And repeat:
I picked up some parts from Honda:
Installed them:
Mounted the tires (learned how to use the tire machines in the process)
Started on the traier
aw, it wants a belly rub
a little measuring, cutting and tack-welding
More measuring, cutting and tack-welding
measurements look good, gonna weld it all up tomorrow
$165 worth of connectors from jegs
Cut off the nipples from the intercooler. Gonna change it up to a -8 an fitting
Gonna weld it tomorrow
Same for the heat exchanger (was a -12 an fitting, gonna make it smaller to be consistent)
Changed up the ice box a little, decided to use 4" pipe instead of making a custom box about the same size/shape:
Still just chillin on the lift
removed some stuff to get a clear shot for tack-welds
Tight fitment
Had to make a custom adapter (not sure where the AC compatible part comes in)
Icebox all welded up
This came out how I saw it in my mind
Everything was a perfect fit (as always)
Made a custom downpipe from scraps
Alot of work done on the trailer lately
Electrical has been wired to match my taillights
Now you can start to see what was in my mind
temporarily spray-painted to prevent rust, might paint it black tho, I like how it looks
Added a 2nd loop to hold the connector when the trailer is unhooked.
Took the car to the show even tho its not done
That tape turned out to be a bitch to peel off
She raised my pole
Sand
Weld
Grind
Prime/Seal
Order Parts:
Powdercoat Parts
Order More parts
Work on motor
Rebuild stuff
More engine work
Type R LSD
Turbo mani:
works again
More turbo parts
=-0
zoomed out a bit:
side skirt is on
Alot more wiring
New overflow tank
-Fluids filled
-Mudflaps installed
-Exhaust installed
-Clutch Bled
-Brakes Bled
-Battery Charged
Still lots to do
A little flake
Perfect Fit!
I chopped them up
And repeat:
Installed them:
Tight fitment
She raised my pole
Right after that carshow someone backed into my car leaving a huge scratch and several small ones that buffed out.
Last weekend I repainted it (good thing I bought extra paint)
hot d4mn that's a nice car dude. I have a sol, this is inspiring all the stuff I've been workin on myself lately.
What's that thing on the passenger side bumper in front of the light? A laser gun?
keep up the good work, i can see you know what you're doing.
(I also got the bumper guards (left) that I gotta stick on, was just waiting to buff the paint first)
Oh and I forgot what the middle one was for
Oh and the reason I started this project finally was because I only won 2nd place at carshows and got to do:
I know it was a slow time, remember it was mostly stock and I didn't feel like beatin the crap out of it. I get nothing for doing that show, and I really had nothing to prove. But after the show, I realized how crappy the paint was, and how slow the car is. Every time I watched the video, I saw how badly I would need a LSD. So this was the main reason for the power upgrades and I was determined to get 1st at a carshow, so thats why everything else.
http://www.youtube.com/watch?v=crNhaQqtiXQ
