aluminum weld on nuts?
Old Jun 2, 2010 | 06:16 PM
mrbsponge's Avatar
Default aluminum weld on nuts?
wondering if anyone has any sites for any aluminum weld on nuts?
been having an issue with some piping blowing off so i figured i would tig a nut on each side of the connection and strap it with a couple bolts. have seen some higher HP cars do it so i figured why not.
anyone have any leads?
thank you
Old Jun 2, 2010 | 08:03 PM
kings_blend's Avatar
Default Re: aluminum weld on nuts?
might just be cheaper to get some solid alum and just drill/tap some bungs
Old Jun 2, 2010 | 09:49 PM
9bells's Avatar
OG Fabricator
Yeah, I usually tap my own aluminum unless it's complicated.
This stuff has proper beads rolled into it and still pops off? Must be a fitment issue or excess tension/load on the coupler...
Seen some pretty crazy HP cars work with bead rolled tubes and t-bolt clamps.
Old Jun 3, 2010 | 04:27 AM
90Rexx's Avatar
vibrant makes exactly what your looking for, check out their website, its a bar that welds onto each side of the charge pipe, with a disconnect if you need to take it apart. i remember seeing them a few years back when they came out.
Old Jun 3, 2010 | 11:01 AM
mrbsponge's Avatar
I would say there might be a slight mis alignment which im going to address while the car is across the way at the paint shop, but i really dont want to go to the track again and have this issue, 3 hour drive to the track to be ruined by IC piping is just a pain in the ***
thanks guys for the repsonses and help
Old Jun 3, 2010 | 03:11 PM
killa@hardocre's Avatar
Nice. This was going to be my response as well.
- Dave.
Old Jun 5, 2010 | 10:13 AM
c5R's Avatar
c5R
http://vibrantperformance.com/catalo...oducts_id=1074 here you go
Old Jun 6, 2010 | 06:41 AM
Fabworx's Avatar
x2
Old Jun 6, 2010 | 07:41 AM
Bailhatch's Avatar
Super cheap...box of 100 3/8 aluminum nuts is about $12.
http://www.mcmaster.com/#aluminum-nuts/=7eyhzz
Old Jun 6, 2010 | 11:00 AM
sgnlab's Avatar
Just make the piping the right way it will never blow off.
EF9_TryMe
Welding / Fabrication
10
Sep 11, 2012 09:48 AM
likwidchz
15
Aug 26, 2011 05:11 PM
SovXietday
23
Jun 17, 2011 06:43 AM
mastakmk
Oct 3, 2007 08:15 PM
funvtec
19
Jun 17, 2005 01:44 PM
