98 b16a2 VTi into 99 DC2 ITR ???? possible??
Old Jun 2, 2010 | 04:51 PM
mmcsiggi's Avatar
Default 98 b16a2 VTi into 99 DC2 ITR ???? possible??
can i put wiring harness from 98 VTi into DC2 ITR??
i got 99 DC2 ITR motorles boddy and also a 98 VTi sedan boddy b16a2.
what im gonna use from the 98 is the motor, ecu and eninge harness.
the harness to the tail lights are good in the teggy and also the litle harness with all the plugs for the cluster, clock and that.
but the wiring harness in the integra that runs across the interior firewall and connects into the ecu is badly damage and also is the harness that goes into the hood to the head lights. So can i use the harness from the VTi instead??????????
Old Jun 3, 2010 | 07:07 AM
Milano-ITR's Avatar
Default Re: 98 b16a2 VTi into 99 DC2 ITR ???? possible??
Does anyone know ?
Old Jun 3, 2010 | 02:53 PM
mmcsiggi's Avatar
bump
Old Jun 3, 2010 | 03:29 PM
Tyrant_007's Avatar
You might try this question in the Hybrid forum to get more answers. The way I see it, is it's a DOHC Vtec B-series OBD2 motor, and that is what's in an ITR stock. I'd say it "MIGHT" work depending on size, emissions equipment and such. I'm not 100% certain though.
Good luck!
Old Jun 3, 2010 | 05:20 PM
clayton bigsby's Avatar
Im pretty sure that the harness from a civic 96-00 wont work on a dc2 chassi, someone correct me if im wrong.
Old Jun 3, 2010 | 05:25 PM
Eran's Avatar
HT White Ops
No. 96-00 Civic's have a one-piece harness that goes directly to the ECU via a boot in the firewall.
92-95 Civics, and 94-01 Integra's have a two-piece harness that plugs into the dash harness via leads from inside the cabin.
Old Jun 4, 2010 | 09:47 AM
mmcsiggi's Avatar
so i can use the harness from 92 civic??
and do you know where i can get it?? cant find anything on ebay
Old Jun 4, 2010 | 10:23 AM
Eran's Avatar
HT White Ops
You'll want to use a harness that has the correct plugs for your year motor. If your motor is OBD2, you'll need an Integra harness.
Old Jun 4, 2010 | 10:48 AM
mmcsiggi's Avatar
i see
i found these 2
http://cgi.ebay.com/ebaymotors/98-99...item3f004aa6b6
http://cgi.ebay.com/ebaymotors/98-01...item3eff300007
does it metter if its from a gsr or a ls ?
thanks for the answers
Old Jun 4, 2010 | 10:56 AM
Tyrant_007's Avatar
GSR will have the vtec solenoid plug where an ls wouldn't.
Old Jun 4, 2010 | 03:08 PM
dmxbmx's Avatar
i see
i found these 2
is the car rhd? if so a usdm wont work
Old Jun 5, 2010 | 10:47 AM
mmcsiggi's Avatar
its lhd
Root of all Evil
Sep 18, 2014 01:57 PM
milkwasabadidea
Jul 31, 2011 01:05 PM
kensei
Aug 6, 2010 04:26 AM
mmcsiggi
Jun 3, 2010 02:53 PM
